rebuilt turbo b18 + del sol + AC = huh?
Old Jul 26, 2005 | 12:51 PM
cappelhans's Avatar
Default rebuilt turbo b18 + del sol + AC = huh?
A question for you guys who have done a turbo setup in a civic/delsol/crx and kept the AC - I have a fully rebuilt turboed b18c1 in a Del Sol and it is a REALLY tight fit with the big turbo and the A/C compressor and fan all crammed up front. The work is all careful and professional (Sportcar Motion did everything).
The weird thing is we're still running hot - but not at idle - only at high speeds or when there's enough load on the engine. Things we're investigating:
-stock temp gauge is wacko
-ecu has the car running lean @3-4K and hence hot
-water pump is dying
hopefully one of these will turn out to be the problem - but if not i'm being told that they may have to pull the A/C. We've already spent so much time and energy to get this setup to work w/AC installed that I would hate to pull it at this point - so if any of you have done tight turbo setups that kept the A/C please give us any pointers you might have to help troubleshoot.
Thanks in advance
chris
PS. The other odd thing is that after the original turbo install the car would overheat in traffic but not at freeway speeds. After switching out slimfan for the stock one and rebuilding the entire engine - it now overheats after ~2-3 miles on the freeway. In both cases the A/C was installed. Huh? Does not compute!
Old Jul 26, 2005 | 01:44 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: rebuilt turbo b18 + del sol + AC = huh? (cappelhans)
check for air bubbles in coolant, also check your headgasket with a compression check
gl
brian
Old Jul 26, 2005 | 02:21 PM
cappelhans's Avatar
Default Re: rebuilt turbo b18 + del sol + AC = huh? (coptzer)
coolant's been flushed and refilled several times and any bubbles bled out - headgasket is literally brand new...!
Old Jul 26, 2005 | 07:24 PM
cappelhans's Avatar
anyone?
Old Jul 26, 2005 | 07:32 PM
NumberB's Avatar
maybe change thermostat and make sure the fan was rewired the correct way.
Jay Lowe
Sep 7, 2014 08:15 PM
jdmitrswapped
May 25, 2010 10:42 PM
bumsta217
Jun 13, 2006 09:35 AM
cappelhans
Jul 27, 2005 02:29 PM
delsol10psi
Oct 12, 2004 04:30 PM
