very fast teg vid.
Look at the rate of acceleration....
that is pretty damn quick IMO...
The Teg belongs to Tony The Tiger here on HT.com...when it was NA....it is now ITB/Turbo'd....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Viper8L488 »</TD></TR><TR><TD CLASS="quote">what is 225 km/h in mph? I am too lazy to go look in my car.</TD></TR></TABLE>
Well wuts the last registered speed in MPH? Likely 130mph. Or divide by 1.6...here...I just did it for you...140mph....
You guys need to squint a bit more as the 140mph is clearly visible in the video....but just like you guys south of the border.... US > all
it seems to be making power all the way to 9000rpm and also it goes through the revs pretty quick. Maybe it has a 4.9 final and a light weight flywheel. It looks like 0-60 in about 6 sec. Nice launch too
search for posts under his name.
The car uses a 99ITR tranny for gearing.... so no final drives at all.
Tony does some pretty crazy work tho....something like 51mm ITBs with 13ish compression or more when he was NA....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realis9 »</TD></TR><TR><TD CLASS="quote">do you know what mods tony the tiger had while he was NA? car is pretty fast.</TD></TR></TABLE>
I know the cams were Toda Spec B's when that video was made. Not sure about the bottom end.
Tony the tiger from Toronto, Ontario, Canada... that vid was shot on a completely NA motor, I think it was making a 250 WHP... he is now Turbo'd w/ ITB's.... Its even faster... man the vid was shot years ago and I still see it floating around the net.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaVAGE00 »</TD></TR><TR><TD CLASS="quote">Tony the tiger from Toronto, Ontario, Canada... that vid was shot on a completely NA motor, I think it was making a 250 WHP... he is now Turbo'd w/ ITB's.... Its even faster... man the vid was shot years ago and I still see it floating around the net.</TD></TR></TABLE>
I almost never seen turbo R's with ITB's
needs some pic
needs some pic
http://www.geocities.com/leung....html
Search for his posts under his SN.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 »</TD></TR><TR><TD CLASS="quote">
needs some pic
needs some pic
I remember seeing that teg in action in toronto, man was it ever fast
he was pretty much unbeatable in the streets
i just never imagined tony going turbo he was so against it esp on a honda he was a hard core NA guy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 »</TD></TR><TR><TD CLASS="quote">I almost never seen turbo R's with ITB's
needs some pic
Its not an R, its a gsr motor.
needs some pic
</TD></TR></TABLE>Its not an R, its a gsr motor.
i just saw the video.
That green teg is one serious car
my car will have 12+ compression N/A setup.. this one makes me wanna go boost
.. that car will make my N/A R look SLOW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel »</TD></TR><TR><TD CLASS="quote">search for posts under his name.
</TD></TR></TABLE> that describes my motor
only better cams, and 85mm pistons
hoping to make around 250 whp, if not, its going to be stroked to 2.2 real soon.
if you watch the video it says mph also,
it's just like our tachs but swapped
(it has kph on the outside an mph on the inside in smaller numbers)
it stops at about 140mph
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by metal-x »</TD></TR><TR><TD CLASS="quote">I remember seeing that teg in action in toronto, man was it ever fast
i just never imagined tony going turbo he was so against it esp on a honda he was a hard core NA guy</TD></TR></TABLE>
Same here, I really never thought of going turbo until the day I discovered the potential of high compression ball bearing turbo setup with ITB's. The car revs like an NA car but with 300+ WHP
Only drawback was the time involved to tune the setup, but I had no probs with that.
Brief facts on the NA (3 year-old) video:
1.8L 12.5:1 CR B18C1
USDM ITR transmission (should be obvious looking at the RPM/km/h)
TODA Spec B's
Hytech Header
Apexi PowerFC
215 WHP
Toyo RA-1 tires I believe
Roughly 2600 lbs without driver
I am really happy the video is still floating around
Only drawback was the time involved to tune the setup, but I had no probs with that.Brief facts on the NA (3 year-old) video:
TODA Spec B's
Hytech Header
Apexi PowerFC
215 WHP
