Suspension & Brakes Theory, alignment, spring rates....
New/Improved Beaks kit for EK chassis?
Old Jul 26, 2005 | 07:32 AM
gabebauman's Avatar
Default New/Improved Beaks kit for EK chassis?
EDIT They ended up shipping me the original kit. Works great...now I have 22mm rear bar...understear has not been a problem.
Thanks
Existing EK kit:
http://beaksproducts.com/SRK_E...t.htm#
Modified by gabebauman at 4:33 PM 10/24/2005
Old Jul 26, 2005 | 10:42 PM
Chester Rumble's Avatar
Default Re: New/Improved Beaks kit for EK chassis? (gabebauman)
If you do some research on the Beaks kit, you'll find that many people have had their subframes still tear out even with the kit. There isn't much to it, and if you really look at it, those small metal pieces wouldn't really reinforce the subframe too much. Check out A-Spec Racing and their braces. Cost more than the Beaks kit, but Im sure most poeple will agree that is better handsdown. Another reason subframes can tear out is because some people dont run spring rates that are stiff enough to balance out a big rear sway bar, like a Type R rear sway bar. If you have some crazy spring rates, you might be able to get away with a Beaks kit, but Id rather get the the A-Spec brace. But good luck on whatever you choose.
http://www.a-spec-racing.com/
Old Jul 27, 2005 | 05:28 AM
gabebauman's Avatar
Default Re: New/Improved Beaks kit for EK chassis? (Chester Rumble)
Thanks...but I've done tons of research on the kit...and the cases which involved tearout are minimal compared to successful usage. This is my daily driver with 335lb rear springs and full stiff agx shocks. I'm well aware of the risk and the ASR kit is on my future list. There are many variables to this topic.
Thank you.
Old Jul 27, 2005 | 05:33 AM
.nate's Avatar
I have the old Beaks setup on my EG... the new one looks very similar...
Old Jul 27, 2005 | 05:46 AM
gabebauman's Avatar
Default Re: (.nate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .nate &raquo;</TD></TR><TR><TD CLASS="quote">I have the old Beaks setup on my EG... the new one looks very similar...</TD></TR></TABLE>
FYI: the pic that I posted above is the "existing" EK kit...the EG kit looks different. I'm looking for info on the "new" EK kit. I'm not sure if they're redesigning the eg kit.
Old Jul 27, 2005 | 06:52 AM
.nate's Avatar
I guess thats why it looks familliar then huh? lol
Old Jul 27, 2005 | 01:18 PM
nonsense's Avatar
I haven't heard anything, but have you tried emailing them?
as for the relpy about the tearouts .... I've read about two seperate incedents and no more. I wonder what the circumstances leading to the failures were??
Old Jul 28, 2005 | 11:39 AM
gabebauman's Avatar
Default Re: New/Improved Beaks kit for EK chassis? (nonsense)
From Beaks email reply:
Boy, news sure travel fast! Yes, the SRK-EK is being redesigned but it won't be ready for another month. A prototype is in the works right now. I will post any picture or info as soon as they are available. Thanks for maintaining interest!
-Wil
http://www.BeaksProducts.com
Old Jul 28, 2005 | 01:04 PM
nonsense's Avatar
Old Jul 28, 2005 | 01:11 PM
gabebauman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
cause I have to wait another month to install my itr rear sway bar...lol. Better be worth it.
Old Jul 28, 2005 | 09:59 PM
veggiemaster's Avatar
having your KYB's stiff wont do much for "anti-tearout"
I currently have a ITR bar on my integra using a BSQ kit. As long as you arent harsh on your car, there shouldnt be any problem running it. This is the second integra ive successfully run a BSQ on.
Old Jul 29, 2005 | 05:44 AM
gabebauman's Avatar
Default Re: New/Improved Beaks kit for EK chassis? (veggiemaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veggiemaster &raquo;</TD></TR><TR><TD CLASS="quote">having your KYB's stiff wont do much for "anti-tearout".</TD></TR></TABLE>
Yeah...but I don't autox and maybe one or two road/track sessions per year...I'm not worried to much.
Thanks
Old Aug 1, 2005 | 01:42 PM
joshxcuh's Avatar
does anyone know if the beaks kit will work with my progress 22mm rear sway bar?
Old Aug 1, 2005 | 06:32 PM
JDMFreak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chester Rumble &raquo;</TD></TR><TR><TD CLASS="quote">Another reason subframes can tear out is because some people dont run spring rates that are stiff enough to balance out a big rear sway bar, like a Type R rear sway bar. </TD></TR></TABLE>
can you help me on my search. i have read alot of subframe being teared out. but i dont know what or where to search for. is there a list? maybe we can go by for example. ITR Rear Sway Bar vs XXX spring rate
Old Aug 1, 2005 | 07:21 PM
nonsense's Avatar
Default Re: New/Improved Beaks kit for EK chassis? (JDMFreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMFreak &raquo;</TD></TR><TR><TD CLASS="quote">can you help me on my search. i have read alot of subframe being teared out. but i dont know what or where to search for. is there a list? maybe we can go by for example. ITR Rear Sway Bar vs XXX spring rate</TD></TR></TABLE>
I've never seen a straight answer to this question. Fact is there have only been a few tearouts with the Beaks kit and I don't think it had anything to do with rear rates, it's just a theory at this point. There are lots of people running ITR bars with stock springs and they haven't hat any issues.
Old Aug 1, 2005 | 11:02 PM
JDMFreak's Avatar
I've never seen a straight answer to this question. Fact is there have only been a few tearouts with the Beaks kit and I don't think it had anything to do with rear rates, it's just a theory at this point. There are lots of people running ITR bars with stock springs and they haven't hat any issues. </TD></TR></TABLE>
thank you for that info.
confucioussae
Suspension & Brakes
Sep 13, 2006 03:03 PM
confucioussae
Sep 5, 2006 05:04 AM
BanEL
May 15, 2003 08:51 PM
CptCorN
39
Oct 13, 2002 01:53 PM
JOHN WAYNE
Oct 3, 2002 08:49 PM
