rotor over hub (i have some ??????'s)
Old Jul 26, 2005 | 07:10 AM
THEROPE's Avatar
Default rotor over hub (i have some ??????'s)
ok i first learned the conversion when i was on A-D. i read all the tech stuff they had and after reading about the price it took to do it i thought it would be perfect.
since i called my honda guy and he wanted close to 5 bills to do it the oem way hub over rotor
so after reading all the info on A-D and reading some posts on here i have a question about what hubs i can use. in all the tech articals on A-D they say you have to use 98-99 2.3 cl hubs. but i think i remember a guy saying that he used 98 4cly accord huds because he said they are the same as the 2.3 cl huds and since the accord huds are way cheaper i would like to take that route when i do the conversion.
so the question is instead of using the 2.3 cl hubs can i use 98 4cly accord hubs?
Old Jul 26, 2005 | 08:57 AM
notoriousB's Avatar
Default Re: rotor over hub (THEROPE)
yes. the CL and accord hubs are the same.
Old Jul 26, 2005 | 09:06 AM
THEROPE's Avatar
Default Re: rotor over hub (notoriousB)
THANK YOU
Old Jul 26, 2005 | 10:47 AM
THEROPE's Avatar
that answer just saved me 40 bills
Old Jul 26, 2005 | 11:20 AM
notoriousB's Avatar
glad I could help.
you can paypal me my cut.
Old Jul 26, 2005 | 03:08 PM
MestizoRacer310's Avatar
I went with the 92-95 Prelude spindle/strut rod/lower control arms. For some odd reason, I came out with 4.3 degress of POSITIVE camber. The lca's are the same length and the previous guy's car this exact setup was on had negative camber. (BTW I'm lowered 2")..........I had -2.2 degress before the swap. What gives? (Sorry to hi-jack)
I may go with the 98+accord/cl setup if I can't get this resolved ASAP.
Old Jul 27, 2005 | 04:06 AM
THEROPE's Avatar
Default Re: rotor over hub (MestizoRacer310)
thats a good question sorry i cant answer it. im still learning about suspension
but its no hi-jack if you find your answer in this thread great
NGUSPEED
Suspension & Brakes
Feb 4, 2017 02:19 PM
hodrod
Suspension & Brakes
Mar 7, 2015 10:36 AM
Stagerguy
Jan 11, 2013 05:59 PM
LM1092
Apr 10, 2012 10:38 AM
732xghost
May 30, 2009 05:33 PM
