valve adjustment specs on skunk2 stage 2 cams?
Old Jul 26, 2005 | 05:13 AM
veilsides2000's Avatar
Default valve adjustment specs on skunk2 stage 2 cams?
what are the specs on adjusting the valves if i put skunk2 stage2 cams on??? is it factory spec?? intake:0.006 exhaust:0.007??
Old Jul 26, 2005 | 06:13 AM
IN VTEC's Avatar
Default Re: valve adjustment specs on skunk2 stage 2 cams? (veilsides2000)
They recommend .007" IN and .008" EX.
Old Jul 26, 2005 | 06:30 AM
Default Re: valve adjustment specs on skunk2 stage 2 cams? (IN VTEC)
because of the higher lift and duration?? where did you find this info?? thanks again
PYITR821
Mar 1, 2004 10:18 PM
sleepycivix
Nov 15, 2002 08:01 PM
sleepycivix
Nov 15, 2002 07:01 PM
-Racer X-
Jul 11, 2002 08:34 PM
