do omni coilovers go low
instructions are explicit that the shock and spring must have preload to work properly, they help and create the movement between lower spring perch and spring
why would you sacrfice yoru safety and performance for 'da look'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 »</TD></TR><TR><TD CLASS="quote">
why would you sacrfice yoru safety and performance for 'da look'</TD></TR></TABLE>
saftey i have no clue about, but pre-load does ZERO for performance.
There have been a billion threads about this, pre-load does nothing for performance.
well, when you raise your car with lowering springs, the spring comes off the perch, if you set the car back down and it doesnt sit right, then bad things can happen.
ive seen a skunk2 coil sit crooked on a strut and cause damage. so, preload is good for that reason i suppose.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veggiemaster »</TD></TR><TR><TD CLASS="quote">well, when you raise your car with lowering springs, the spring comes off the perch, if you set the car back down and it doesnt sit right, then bad things can happen.
ive seen a skunk2 coil sit crooked on a strut and cause damage. so, preload is good for that reason i suppose.</TD></TR></TABLE>
take the extra 2 seconds to make sure it sets right, if you have 1 brian cell its not hard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">take the extra 2 seconds to make sure it sets right, if you have 1 brian cell its not hard</TD></TR></TABLE>
you are right, its not hard, but it happens.
im runnin the sports.....dont know about ur 2nd question
when i put my S-T sway bars on with my old suspension it raised me up a lil bit so idk if i could go lower with the omnis now if i were to take them off...
