crx si with civic si engine? straight swap?
Hi
i have a CRX si (aussie model) which comes stock with a D16a8
was wondering about changing the block from a Civic si 1993 hatch which also has a d16a8
was wondering if the head and block will bolt up with everything in my crx and be simple no hassles..
cheers
cheers
If its the same engine code then its the same engines, just that the one from the 93 is most likely obd1. So just use the block and head and swap all of your other parts over to it, i.e., intake manifold, dist, sensors, etc.
uvamosk
Sep 19, 2005 08:56 AM
onemanlan
May 24, 2004 06:51 PM
