just a question i hope doesnt get LOCKED
Old Jul 26, 2005 | 12:03 AM
siregcivic's Avatar
Default just a question i hope doesnt get LOCKED
IM NOT GONNA POST A SENTANCE WHY
WILL A D16Y8 DISTRIBUTOR FIT ON A D16Z6?
Old Jul 26, 2005 | 12:05 AM
komat's Avatar
Default Re: just a question i hope doesnt get LOCKED (siregcivic)
dont know if they fit or not
but one is odb2 and the z6 is odb1
the connectors wont fit unless you rewire it
do a search for the answer
i remember reading something about it couple months ago
Old Jul 26, 2005 | 01:20 AM
siregcivic's Avatar
Default Re: just a question i hope doesnt get LOCKED (komat)
oh i will explain now... i am going to be putting a d16z6 motor into a 98 ex coupe switching all sensors.. fuel rail and fuel injectors and i wanted to know if it would bolt up or not.. i did search for it btw
Old Jul 26, 2005 | 02:14 AM
05em2's Avatar
vtec ones will not fit on nonvtec motors and vice versa, mountings are different
hope that helps, someone correct me if im wrong, but the ddizzy froma 4 door 94 lx did not fit in my 93 ex
Old Jul 26, 2005 | 03:57 AM
JDM-EJ1's Avatar
Default Re: just a question i hope doesnt get LOCKED (Jay-Dee-Em)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay-Dee-Em &raquo;</TD></TR><TR><TD CLASS="quote">vtec ones will not fit on nonvtec motors and vice versa, mountings are different
hope that helps, someone correct me if im wrong, but the ddizzy froma 4 door 94 lx did not fit in my 93 ex</TD></TR></TABLE>
Correct.
Old Jul 26, 2005 | 11:25 AM
siregcivic's Avatar
Default Re: just a question i hope doesnt get LOCKED (JDM-EJ1)
no im going to be using the d16y8 distributor on a d16z6 will it bolt up?
Old Jul 26, 2005 | 11:26 AM
JDM-EJ1's Avatar
No, because the y8 is OBD2, while your z6 OBD1 you'll have wiring issues.
Old Jul 26, 2005 | 11:31 AM
EK k kay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay-Dee-Em &raquo;</TD></TR><TR><TD CLASS="quote">vtec ones will not fit on nonvtec motors and vice versa, mountings are different </TD></TR></TABLE>
That is incorrect. Some non-vtec and vtec distributors like the y7 and y8 are identical. However the z6 distributor is different from the b7 so it will not be interchangable.
Old Jul 26, 2005 | 12:20 PM
siregcivic's Avatar
Default Re: just a question i hope doesnt get LOCKED (wadup)
AHHHHH
can someone just please answer my question.. i am putting a 95 d16z6 motor in a 98 ex car that had a d16y8 at once... i am swapping everything over... all the sensors injectors and everything to make it compatable with the obd2...
okay now my question is... WILL THE Y8 DISTRIBUTOR FIT ON THE Z6 HEAD YES OR NO.
not no because its obd whatever i dont care.... WILL IT BOLT UP CORRECTLY THATS IT
Old Jul 26, 2005 | 05:20 PM
CivicMike's Avatar
i wonder what would happen if i used a z6 dist on my y8.....
Old Jul 26, 2005 | 06:30 PM
james p.'s Avatar
if my Z6 dizzy can (simply) bolt up to a Y8 than i'm guessing... YES.
Old Jul 26, 2005 | 07:49 PM
ABK's Avatar
ABK
God if you don't know what you are talking about, just don't talk ait???
There is no such thing as a vtec dizzy.
I might be mistaken (it's been a while since I was all into the d series and stuff. I might be wrong but y8/y7 dizzys got the same bolt pattern as a obdI dizzies (except z6 and jdm d15b, same thing). So I don't think that y8 dizzy will bolt up to a z6 head, but you can either bolt it up with either 1 or 2 bolts, and I've also heard of people using a dremel to make bolt holes bigger.
You can also take a z6 dizzy and convert it to a obdII plug.
Old Jul 26, 2005 | 07:53 PM
Junk Ex's Avatar
Default Re: just a question i hope doesnt get LOCKED (ABK)
why don't you just convert everthing to obd1? everone seems to do that when they boost the newer year cars.
Old Jul 26, 2005 | 07:56 PM
JDM-EJ1's Avatar
Default Re: just a question i hope doesnt get LOCKED (Junk Ex)
Okay, here is the correct answer.
The y8 dizzy that you have will not directly work with your z6, you'll have to convert it to OBD1 first.
Old Jul 26, 2005 | 08:08 PM
siregcivic's Avatar
omfg im sooo sorry you guys just do not understand okay.... the car is completely STOCK its not gonna be converted to race or anything like that
okay
i am going to be putting a d16z6 into a 98 ex.. okay i have the y8 motor but the bottom end is blown due to the #3 cylinder problem they have okay..... im going to be using all of the obd 2 sensors on the d16z6.. im not converting anything...
ALL I WANT TO KNOW IS..... WILL THE Y8 DISTRIBUTOR BOLT UP TO THE Z6 HEAD ... I DONT WANT TO HEAR NO CRAP ABOUT OBD WHATEVER.... JUST WILL IT BOLT UP BEFORE I GO OUT AND BUY THE MOTOR AND NOT BE ABLE TO USE IT...
SORRY ABOUT WAISTING TIME.. JSUT ONE STUPID QUESTION CANNOT GET ONE ANSWER
Old Jul 26, 2005 | 08:13 PM
ABK's Avatar
ABK
no it won't, bolts don't line up. He will need to convert a z6 dizzy to OBDII if he is trying to use it in a obdII car.
Or he can dremel the y8 out and make it hold on by 2 bolts.
so many newbies these days, that just say whatever they want.
Old Jul 26, 2005 | 08:46 PM
Blk00EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siregcivic &raquo;</TD></TR><TR><TD CLASS="quote">I DONT WANT TO HEAR NO CRAP ABOUT OBD WHATEVER.... JUST WILL IT BOLT UP BEFORE I GO OUT AND BUY THE MOTOR AND NOT BE ABLE TO USE IT...</TD></TR></TABLE>
You know, your rash responses are clear that you don't understand what the people who are posting in your thread are even saying. The possibility of it working from you holding it in your hand to sticking it on the engine are directly related to OBD1 or OBD2. IF it happens to bolt up, whether you modifying the bolt holes or not, the OBD situation is that the sensors are different so they will need to be modified.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siregcivic &raquo;</TD></TR><TR><TD CLASS="quote">im going to be using all of the obd 2 sensors on the d16z6.. im not converting anything...</TD></TR></TABLE>
There are no OBD2 sensors on the d16z6 because its not OBD2. If you're gonna use it then YES, YOU WILL BE CONVERTING. Geez, why's that so hard to understand?
If you don't understand the principles of OBD then I don't know how you're going to accomplish this swap, especially because youre planning on putting an OBD1 engine into an OBD2 car.
Old Jul 26, 2005 | 08:57 PM
siregcivic's Avatar
Default Re: just a question i hope doesnt get LOCKED (EKcivicEX)
okay i am sorry for the rash post okay
like i said above.. im going to be putting the obd 2 sensors into the d16z6 taking the obd1's out... i do understand obd's... i just wanted a simple answer.. not get into this whole tech bla bla.... just will it bolt up or not... it doesnt matter what obd because i am switching everything over to the z6.... this is already a big hassle.. i was gonna save the guy 500 bucks buy going to my guy to get the z6 for 200 other than 700 for a y8..
Old Jul 26, 2005 | 09:06 PM
eK9aT10pSi's Avatar
it will bolt up but for a stock car, the wiring connectors wont work 1st of all. 2nd the timing on a z6 is 16deg while the y8 is 12deg. [im wondering if it affects the dizzy side or the cam side?]
Old Jul 26, 2005 | 10:30 PM
siregcivic's Avatar
Default Re: just a question i hope doesnt get LOCKED (eK9aT10pSi)
why wont the connectors work
i am going to be putting all of the obd2 stuff on the z6.... ie sensors injectors everything.... and im going to be using the obd2 harness... but this is getting too complicated nobody can tell me yes it will fit or no it wont fit so im just gonna tell the guy to get another y8 for 700 and hope it doesnt have the same problem as the rest of them... thank you for all the unusefull compliments everyone else... a simple yes or no would have worked well but its cool
Old Jul 27, 2005 | 04:53 AM
CivicMike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siregcivic &raquo;</TD></TR><TR><TD CLASS="quote">why wont the connectors work
i am going to be putting all of the obd2 stuff on the z6.... ie sensors injectors everything.... and im going to be using the obd2 harness... but this is getting too complicated nobody can tell me yes it will fit or no it wont fit so im just gonna tell the guy to get another y8 for 700 and hope it doesnt have the same problem as the rest of them... thank you for all the unusefull compliments everyone else... a simple yes or no would have worked well but its cool</TD></TR></TABLE>
what problem?
Old Jul 27, 2005 | 05:12 AM
BauleyCivic's Avatar
Risky Business
Default Re: just a question i hope doesnt get LOCKED (CivicMike)
D15B2/D16A6 - D15B7 - D16Y7/D16Y8 all have the same bolt pattern
D16Z6 - JDM D15B - D15Z1 have the same bolt pattern
<U>No</U> OBD2 distributor bolts directly up to the D16Z6. You can drill out the holes for a D16Y8 dizzy and it might work, but i'm not guaranteeing anything.
Old Jul 27, 2005 | 05:15 AM
d16rice's Avatar
<U>NO it will not work</U>, and this is how I know it:
First off, d16y7 and d16y8 distributors are the same. I’m currently running a mini-me (Y7 engine block and distributor, everything else Y8), and it works fine.
I also have a Z6 distributor laying around my house, and the mounting brackets have a different pattern (than Y7/Y8), the holes do NOT line up. I’d take a picture, but I’m leaving for the airport, cheers.
Old Jul 27, 2005 | 05:18 AM
Risky Business
Default Re: just a question i hope doesnt get LOCKED (d16rice)
^ he's right too
Old Jul 27, 2005 | 05:19 AM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16rice &raquo;</TD></TR><TR><TD CLASS="quote"><U>NO it will not work</U>, and this is how I know it:
This is correct.
