tach jumps around and car surges "96 accord V6"
My car runs fine untill it warms up. Then the tach jumps all over the place and the car will surge while driving. At stop lights it sets at zero and some times the car will die. I was thinking it might be some sort of sensor but I cant think of which one. My second guess is the distributor needs replaced.
Any help is appreciated,
Wayne
Wayne
ok thanks for the help, I kinda already knew that. I am wondering if anyone else has had a similar problem though.
check your ignition control module inside the distributer...that could be the cause or perhaps a sensor that is inside the distributer is bad...
Bad coil: http://www.v6performance.net/f...=tach
thanks a bunch. I will have to change that and do some major tune up stuff as well. I pulled the distributor cap and the teeth on the cap were about to snap off.
standbackimapro
Aug 25, 2006 01:29 PM
dlbshonda
Jul 31, 2002 05:17 PM
