auto to manual tranny.... won't start from the ignition
i can manually start it from under the hood but i heard when you do a auto to manual transmission you need to re-wire something from the starter to the ignition any help will work thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR »</TD></TR><TR><TD CLASS="quote">i can manually start it from under the hood but i heard when you do a auto to manual transmission you need to re-wire something from the starter to the ignition any help will work thanks</TD></TR></TABLE>
No, you do not. Just get a manual starter and install it like you normally would and you're golden.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">No, you do not. Just get a manual starter and install it like you normally would and you're golden.</TD></TR></TABLE>
No.
You need to jumper the two largest wires from the shifter harness. It is right in front of the AT shifter.
I personally left the harness there and I just soldered the two together and I was golden. You also have to jump two wires ti signify that you are in park, or you can't get the key out.
No.
stackz
Jan 7, 2007 05:02 PM
GTEC913
Mar 8, 2006 06:11 PM
philosofy1
Jul 18, 2005 08:37 PM
hybridpatient95
Apr 22, 2005 12:38 AM
95greenteg
Nov 19, 2004 11:12 PM
