Front lower control arm? Pictures &or installation?
Hey was up I got a little problem maybe you guys could help me out. I want to install the front lower control arm is it hard to install do I need a lot of tools. Is there a page I could go where they have step-by-step installation with picture or without pictures.
If the car has alot of rust itll take forever. If it doesnt then your set. Also if you have a front sway youll be cursing forever to put the new one in.
Tools needed is 17mm wrench (x2), 17mm socket and 1/2 inch ratchet. Im pretty sure the adjustment bolt is 17mm too. Take off put on easy as cake. Just get it aligned afterwards.
