1 bolt holding down fuel rail?
Old Jul 25, 2005 | 04:34 PM
abmerop18's Avatar
Default 1 bolt holding down fuel rail?
I have a 2002 civic lx coupe turbo and currently am installing form rc 550cc injectors, but am running into a little issue with clearence of one of the sensors on the TB and the fuel rail. the 550cc injectors are alot bigger then my stock ones, or even the rsx-s ones i had in there before, so this was never an issue before. right now i was able to get one of the bolts for the fuel rail in, but the other will not align because of the fitment issue. is it safe to just have the one bolt in and tighten it down really hard so that there is no play in the fuel rail at all and it sits real snug. will this cause any problems?
Old Jul 25, 2005 | 04:36 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: 1 bolt holding down fuel rail? (abmerop18)
its gonna leak
Old Jul 25, 2005 | 04:43 PM
abmerop18's Avatar
Default Re: 1 bolt holding down fuel rail? (wantboost)
then what should i do
Old Jul 25, 2005 | 04:51 PM
wantboost's Avatar
Who is Mr Robot?
well, are you using the spacers that go under the rail? take them out
Old Jul 25, 2005 | 05:29 PM
93turbo16's Avatar
OR, dremel the seals out so the RCs fit down a little tighter.
Old Jul 25, 2005 | 06:18 PM
abmerop18's Avatar
Default Re: (93turbo16)
well, after alot of pushing and squeezing, i was finally able to fit it in.
lilkim0121
Mar 17, 2022 06:34 AM
410ruga
Apr 10, 2014 03:46 AM
slammedbbs
Jul 6, 2011 02:52 PM
zexpoweredem2
Honda Civic (2001 - 2005)
Jul 2, 2007 09:22 AM
