WHAT TO DO????
if i were to get a JDM ITR motor, what would you guys do to make it run in the low 12's [ALL MOTOR]... the motor is in great condition with low miles and has the following mods:
2000 JDM Type R Motor with LSD trans
New Exedy Stage One Clutch
Type R Flywheel
New timing belt and water pump installed
Toda timing belt
Toda cam gears
Toda Header
Spoon ignition wires
C&R Radiator
Real Authentic J's Racing intake
Chipped P28 Kenji program
Vibrant catalyct converter
RSR Exmag exhaust
i am thinking about getting CTR Pistons and a whole Skunk2 head kit. what do u guys think?
or
*this motor will be going in a 2001 GSR with a JDM front end with HID's
what would u guys do to make it run low 12's?? I NEED YOUR HELP HONDA-TECH!!!!
Modified by honda-tech'er at 6:42 PM 7/25/2005
Type R Flywheel
Toda timing belt
Toda cam gears
Toda Header
C&R Radiator
RSR Exmag exhaust
or
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda-tech’er »</TD></TR><TR><TD CLASS="quote">ok. ***.. </TD></TR></TABLE>good luck getting help with that attitude.
:shrugg:
:shrugg:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda-tech’er »</TD></TR><TR><TD CLASS="quote">ok. ***.. u know what i mean.</TD></TR></TABLE>
In that case I suggest:
https://honda-tech.com/zeroforum?id=36
https://honda-tech.com/zeroforum?id=44
https://honda-tech.com/zeroforum?id=18
Why didn't you get the toda B or C cams to make the power you're looking for?
Just interested in the JDM "L00K"?
Not only that, you're reallu going to need to get that Kenji ECU "tuned" as they say, to get it to all work together.
Good luck with the low 12's ...
Lastly, try the hybrid or drag forums as they'd suggested above.
navin
Mid-Atlantic (Sales)
Jan 1, 2008 01:57 PM
RDix
12
Mar 27, 2006 02:31 PM
navin
Aug 15, 2003 09:40 PM
