should i turbo or ls/vtec
Old Jul 25, 2005 | 12:44 PM
laosboy978's Avatar
Default should i turbo or ls/vtec
im planning to buy an integra with a over 100,000 miles from a friend for cheap...should i go ls,vtec or turbo since it is already over 100,000 miles...what is the best type of situation i should do and how much would it cost me for ls/vtec conversion and how much would it cost me to do turbo and would it kill my engine since it already over 100,000 miles thanx
Old Jul 25, 2005 | 12:59 PM
Lan's Avatar
Lan
Default Re: should i turbo or ls/vtec (laosboy978)
I might get flamed for this but I personally think that LS vtec is overated. I have ran plenty of them in my stock gsr and won. If you have the money go TURBO. You can do a basic bolt on kit and safely produce 230 whp maybe more or if you really have some money sleeve the block and you can really have some fun. You would have to upgrade your FM but it'll be worth it. Front mounts look so sick on integras too.
Old Jul 25, 2005 | 01:10 PM
simon98h22's Avatar
Default Re: should i turbo or ls/vtec (Lan)
What year is the teg ? I'd say boost would be more cost effective.
Old Jul 25, 2005 | 01:12 PM
Spec R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lan &raquo;</TD></TR><TR><TD CLASS="quote">I might get flamed for this but I personally think that LS vtec is overated. I have ran plenty of them in my stock gsr and won. If you have the money go TURBO. You can do a basic bolt on kit and safely produce 230 whp maybe more or if you really have some money sleeve the block and you can really have some fun. You would have to upgrade your FM but it'll be worth it. Front mounts look so sick on integras too. </TD></TR></TABLE>
not only 230 whp, but also boat loads more torque than a basic LSVtec would get.
Old Jul 25, 2005 | 01:13 PM
laosboy978's Avatar
Default Re: should i turbo or ls/vtec (simon98h22)
it is a 96 and im not looking to go racing or anything jus want a little more boost then average and what turbo is a decent one for daily driving..also with the engine being over 100,000 would turbo still make my car run smooth?sorry this is my first integra and i dont know much so yes u can call me a noob but it ok im willing to learn...thanks
Old Jul 25, 2005 | 01:24 PM
bigprospect187's Avatar
If the compression tests out ok, and all other basic engine health maintanence has been followed, then I dont see why you can't turbo your teg. I had a friend who turboed his teg with 109,000 miles, and his **** ran like a bat outta hell. You would have though the car was new it was so smooth, that is until it got stolen.
Old Jul 25, 2005 | 01:38 PM
justin.parker's Avatar
I was/am somewhat in the same situation you are. I would say it depends heavily on how badly you want vtec.
Old Jul 25, 2005 | 01:40 PM
xteg95's Avatar
Default Re: should i turbo or ls/vtec (justin.parker)
boost &gt; ls/vtec any day...
Old Jul 25, 2005 | 01:50 PM
Spectrum24x's Avatar
Default Re: should i turbo or ls/vtec (xteg01)
if your worried about the mileage, you could do as i did. Get your motor rebuilt with high compression pistons, new rods, bearings ARP head studs, and go LS/Vtec. Put down a good amount of power.. spank GSRs and type Rs, have a fresh engine, and not have to worry about any reliability..
Only regret i have, is how much more power i coulda made with a turbo
But i wouldnt be as comfortable with the turbo.
Old Jul 25, 2005 | 02:07 PM
INNo's Avatar
between turbo and ls-vtec
go turbo and boost safely, you wont regret it and after running that setup for awhile you can build your bottom end to handle more boost which then you can slap on a vtec head.
Old Jul 25, 2005 | 06:36 PM
ernald711's Avatar
stock GSR vs. LS/VTEC.... hmmm.... and you said you won...... okay?!?!!
anyways... whatever you do, you should prepare your car... i don't believe in slapping in a turbo with a car that had over 100k on it. i guess you can but i care more about reliablitly....
Old Jul 25, 2005 | 07:32 PM
NuclearB18B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laosboy978 &raquo;</TD></TR><TR><TD CLASS="quote">im planning to buy an integra with a over 100,000 miles from a friend for cheap...should i go ls,vtec or turbo since it is already over 100,000 miles...what is the best type of situation i should do and how much would it cost me for ls/vtec conversion and how much would it cost me to do turbo and would it kill my engine since it already over 100,000 miles thanx</TD></TR></TABLE>
why not do both?
Old Jul 25, 2005 | 09:58 PM
Default Re: should i turbo or ls/vtec (NuclearB18B)
turbo ls/vtec=sick numbers
i've seen over 500whp/trq
Old Jul 26, 2005 | 01:01 PM
simon98h22's Avatar
Default Re: should i turbo or ls/vtec (Spectrum24x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spectrum24x &raquo;</TD></TR><TR><TD CLASS="quote">turbo ls/vtec=sick numbers
i've seen over 500whp/trq </TD></TR></TABLE>
Old Jul 26, 2005 | 01:15 PM
Lan's Avatar
Lan
Default Re: should i turbo or ls/vtec (ernald711)
Maybe they weren't built properly I don't know but my car is gifted! I say turbo man go for it.
Old Jul 26, 2005 | 01:21 PM
IntegraBoy04's Avatar
I've seen over 500hp on an all ls-turbo motor. I think you should do TONS of research before you do anything. You don't seem to know too much about what you are doing, and that is how things blow up. Boost is better for the money though. And you can make 300 safely on a stock motor ls.
Old Jul 26, 2005 | 01:22 PM
Rajin's Avatar
Boost it. Thats my vote.
chasedatteg
Apr 17, 2005 06:33 PM
t . b o z
Feb 15, 2004 03:33 PM
teg969
May 14, 2003 05:14 PM
lowcivex
Feb 14, 2003 12:26 PM
ITRfaithful
Jun 6, 2002 04:10 PM
