bfg drag radials
Old Jul 25, 2005 | 12:35 PM
IntegraLs97's Avatar
Default bfg drag radials
has anyone used the drag radials befor and if so what is street wear like any info wood be nice thanks chris
Old Jul 25, 2005 | 12:55 PM
Above6K's Avatar
Default Re: bfg drag radials (IntegraLs97)
BFG drag's are good tires. What have you done to your car mod wise? Are you planning on taking it to the track for occasional racing? If you have any kind of decent power your liable to snap a stock driveshaft with them.
As for their life, they obviously wear faster than most tires. I recommend keeping your stock tires and rims and just buying 2 new rims to mount the BFG's on. So you can switch whenever you want.
Old Jul 25, 2005 | 01:03 PM
Default Re: bfg drag radials (Above6K)
im running a jackson super charger header back exhaust intake 62 mm throttle body jackson fuel pump and injectors im not sure of horse yet but im going to get it dyno soon im just not getting any grip and im just smokeing tires
Old Jul 27, 2005 | 04:33 PM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Above6K &raquo;</TD></TR><TR><TD CLASS="quote"> If you have any kind of decent power your liable to snap a stock driveshaft with them.
No you won't. Stock axles will handle plenty of abuse. It's all in the driving style.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Above6K &raquo;</TD></TR><TR><TD CLASS="quote"> I recommend keeping your stock tires and rims and just buying 2 new rims to mount the BFG's on. So you can switch whenever you want.</TD></TR></TABLE>
Good advice^^. I've only been able to pull about 5K mi.(tops) out of a set. This was normal drving mon-fri, racing sat. night and sun. morning. It got pricey so, after a couple of sets I just had some mounted on 2 seperate rims. They are great tires and a good investment IMO.
Phil
CaliforniaDad
Jan 3, 2014 01:28 PM
CRXherbie91
Feb 18, 2013 05:07 PM
guessohw
Nov 18, 2011 01:39 PM
gsr camel
Sep 23, 2001 03:44 PM
austrian type-R
Aug 5, 2001 07:02 PM
