What's the difference between Honda coolant vs aftermarket ?
Old Feb 18, 2002 | 06:44 PM
96IntegraLS4DR's Avatar
Default What's the difference between Honda coolant vs aftermarket ?
And what are you currently using ?
Thanks.
Old Feb 18, 2002 | 06:54 PM
JL 74's Avatar
Default Re: What's the difference between Honda coolant vs aftermarket ? (96IntegraLS4DR)
The Honda coolant does not have silicates, and a couple of other things that can clog (??? these particles are in microns) the water pump. A few aftermarket coolants have the same, I think Texaco and Prestone has one that are free from those solids. Sierra is another one.
Old Feb 18, 2002 | 09:23 PM
mickey513's Avatar
Honda coolant = rip off. You can get coolant like Prestone, Peak, etc., for $5 from you local auto-part store and it WORKS THE SAME.
Old Feb 18, 2002 | 09:49 PM
JL 74's Avatar
Default Re: What's the difference between Honda coolant vs aftermarket ? (mickey513)
You are probably right. I am having a hard time accepting their "non-use of coolants which containts particles (that you can't even see in a microscope)" argument that they might clog water pumps.
Same thing with the MTF. I don't know of any significant tranny design changes from 1996 and 1997.
1996? and older manuals calls for 10w-30 or 10w-40 motor oil. And since they 'developed' their MTF and spent $$$ marketing, labeling, and etc. They now swear by it.
Old Feb 21, 2002 | 08:46 AM
4doorH22's Avatar
Default Re: What's the difference between Honda coolant vs aftermarket ? (jl74)
The Peak pre-mixed 50/50 I'm using lists silicates in the ingredients. I'm guessing I should change it?
I know at least one guy who had a water pump fail and is pretty sure it was due to silicates.
Old Feb 21, 2002 | 09:08 AM
Ubermensch's Avatar
Any Aluminum safe coolant should be fine.
If your coolant lists silcates I'd fllush it.
Old Feb 21, 2002 | 09:38 AM
jonsteR's Avatar
This might help.
Old Feb 21, 2002 | 09:46 AM
4doorH22's Avatar
Default Re: What's the difference between Honda coolant vs aftermarket ? (jonsteR)
Good stuff. Thanks!
T_Rex
Nov 9, 2002 06:21 PM
pucho
Oct 5, 2002 02:18 PM
