skunk2 stage2 cams on itr valvesprings.... QUESTION
whats up all. i want to run skunk2 stage 2 cams on a set of ITR valvesprings. my question is... how safe or unsafe is it? am i risking valvefloat? also, whats the highest possible rpm can i take it? thanks
Why not just upgrade the whole valve train since you are going to be putting in cams anyway? You might as well upgrade the springs incase you run it into redline. The stiffer springs will reduce the chance of you hitting a valve.
You need to upgrade the valve springs at the same time as doing the cams. The lift on the S2 stg2's is to large for the stock itr valve train, there is a very good chance that the stock springs will bind causing you to drop valves very quickly.
Brandon
Brandon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TEXASITR603 »</TD></TR><TR><TD CLASS="quote">iam running stage 2 on stock valvesprings, and have been for a while. nothing wrong yet. i think as long as you dont take it past your stock redline,i would say it would be ok.
that's the thing i want to go atmost 9500
</TD></TR></TABLE>that's the thing i want to go atmost 9500
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TEXASITR603 »</TD></TR><TR><TD CLASS="quote">i think as long as you dont take it past your stock redline,i would say it would be ok.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OH_SNAP10k_SHIFT! »</TD></TR><TR><TD CLASS="quote">
that's the thing i want to go atmost 9500</TD></TR></TABLE>
Why?
Why?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nholmes »</TD></TR><TR><TD CLASS="quote">
Why?</TD></TR></TABLE>
why not? isn't that what those cams are for? high rpm
midnighteg-6
Nov 19, 2009 03:32 PM
Euro98ITR
Sep 15, 2008 02:47 PM
hondadriver
Sep 11, 2006 09:55 AM
