Accord 2000 fuel system Flush
Old Jul 25, 2005 | 08:06 AM
shotayute's Avatar
Default Accord 2000 fuel system Flush
Is there a way to reset the fuel system after doing a flush?
after i flushed it, my car have been stalling and the mechanics tells me nothign looks wrong.
can anyone shed some light on this
Old Jul 25, 2005 | 08:51 AM
iakona's Avatar
change your fuel filter. you may just have a clog in the line.
Old Jul 25, 2005 | 09:51 AM
shotayute's Avatar
Default Re: (iakona)
isnt the filter in the gas tank?
Old Jul 25, 2005 | 10:33 AM
shotayute's Avatar
Default Re: (shotayute)
I was told that there is also a little switch/button under the hood that i have to reset.
is this true?
Old Jul 25, 2005 | 10:56 AM
iakona's Avatar
i don't know about the button, but resetting the ECU is done by pulling the fuse, but i don't know if you have an IMM system on board if that will work.
and the fuel filter is up front mounted to the inner side of the fender low by the crank pulley. it's a canister looking device.
Old Jul 25, 2005 | 11:55 AM
shotayute's Avatar
thanks for the input.
some guyu look at it for me, he said he is a mechanic for 27 years now..
he opened my hood and there is a little button towards the back close to where the wiper blades are and he pulled off a little cap and there is a little button that he said thye needed to push in to reset it the fuel system.
then he went user the car and i guess he took off the filter and reconnected it. he said that should fix it, so i will have to see.
JohnnyM
Aug 3, 2009 09:13 PM
ezol
Jun 15, 2007 03:40 PM
Mychal71
Aug 18, 2006 05:40 PM
F22a1stick
Oct 16, 2005 06:17 PM
euclid
Oct 10, 2004 07:15 PM
