D16Z6 Distributor Wiring/Question
I am in the middle of installing a D16Z6 into my Sedan and came across two things -
1) Are the pinouts on the D16Z6 OBD-1 Distributor the same as the D16A6 OBD-0 distributor, relative of course due to the different plugs.
2) Can an OBD-1 Distributor wired up properly be used to fire up the motor even for testing with an OBD-0 ECU?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">
1) Are the pinouts on the D16Z6 OBD-1 Distributor the same as the D16A6 OBD-0 distributor, relative of course due to the different plugs.</TD></TR></TABLE>
wires should all match up i believe
2) Can an OBD-1 Distributor wired up properly be used to fire up the motor even for testing with an OBD-0 ECU?</TD></TR></TABLE>
no, the obd0 ecu won't work if your using a obd1/obd2 dizzy. either convert to obd1 and run a p28, or run an a6 dizzy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elmalouno »</TD></TR><TR><TD CLASS="quote">wires should all match up i believe
no, the obd0 ecu won't work if your using a obd1/obd2 dizzy. either convert to obd1 and run a p28, or run an a6 dizzy.</TD></TR></TABLE> The problem is I do not have a spare P28 lying around, nor is my P06 Chipped for P28 maps. What makes the OBD-1 distributor incapatable with the OBD-0 Electronics?
almostjdmeg
Nov 11, 2008 01:08 PM
a6, d16z6, distributor, distrubitor, distrubutor, fire, honda, obd, obd0, obd2a, p06, pinout, testing, wire, wiring
