GSR brakes/conversion, Brembo, Si master cylinder and prop vavle, steel braided lines
Old Jul 24, 2005 | 09:35 PM
JDMjdawg's Avatar
Default GSR brakes/conversion, Brembo, Si master cylinder and prop vavle, steel braided lines
SOLD TO ROLLINONFIFTEENS
I'm selling my old brake setup from my Civic now that I have an S2000.
GSR brakes front and rear
Brembo cross drilled rotors
ARP extended wheel studs
Goodrich steel-braided brake lines (front)
e-brake cables
New OEM Honda trailing arm bushings
New OEM Honda rear pads
Civic Si master cylinder and 40/40 prop vavle
rotors, brake lines, pads, bushings all have about 2300 miles on them.
A similar setup minus the rotors, ARP's, new bushings, cables went for $520. I'm looking to get $650 OBO...I have alot more that invested in this I have acct's with FedEx and UPS so shipping won't be too much.
I have no rear brake lines, some stock or steel braids can be found for cheap though. I didnt really bother cleaning the rear rotors, it was way too hot! The rust will come right off as soon as you step on the brakes though.
Modified by JDMjdawg at 9:45 PM 8/19/2005
Modified by JDMjdawg at 10:55 PM 8/23/2005
Modified by JDMjdawg at 12:21 PM 8/28/2005
Old Jul 24, 2005 | 11:09 PM
JDMjdawg's Avatar
Default Re: GSR brakes/conversion, Brembo, Si master cylinder and prop vavle, steel braided lines (JDMjdawg)
ttt
Old Jul 25, 2005 | 05:25 AM
JDMjdawg's Avatar
up
Old Jul 25, 2005 | 11:09 AM
JDMjdawg's Avatar
hmm...bump
Old Jul 25, 2005 | 02:07 PM
JDMjdawg's Avatar
someone must need brakes...
Old Jul 25, 2005 | 04:28 PM
JDMjdawg's Avatar
up y0!
Old Jul 25, 2005 | 05:31 PM
JDMjdawg's Avatar
bump
Old Jul 25, 2005 | 08:22 PM
JDMjdawg's Avatar
uppity
Old Jul 25, 2005 | 10:34 PM
JDMjdawg's Avatar
up again....
Old Jul 25, 2005 | 11:11 PM
EH..phantom's Avatar
wouldnt be willing to part out the prop valve??
Old Jul 26, 2005 | 05:24 AM
JDMjdawg's Avatar
Default Re: GSR brakes/conversion, Brembo, Si master cylinder and prop vavle, steel braided lines (EH..phant
Nope, sorry.
Old Jul 26, 2005 | 04:26 PM
JDMjdawg's Avatar
bump..someone make an offer already!
Old Jul 26, 2005 | 09:35 PM
JDMjdawg's Avatar
up it goes...
Old Jul 26, 2005 | 09:52 PM
EK2.0's Avatar
Will this set-up fit on a 97 civic hatch? And what else is needed, just the rear brake line? thanks
Old Jul 26, 2005 | 11:06 PM
JDMjdawg's Avatar
Default Re: (JDMLVR)
This setup will work perfectly on an EK...Thats exactly what I had it on before All you need are the rear brake lines, I can get them for you if you want, steel braided or OEM Honda. Hit me back
Old Jul 26, 2005 | 11:42 PM
yoshi_1r's Avatar
$700 shipped to 41042?? so its just bolt on to an ek???
Old Jul 27, 2005 | 05:27 AM
JDMjdawg's Avatar
Default Re: (yoshi_1r)
Pm'd
Old Jul 27, 2005 | 11:01 AM
JDMjdawg's Avatar
up
Old Jul 27, 2005 | 03:34 PM
JDMjdawg's Avatar
bump
Old Jul 28, 2005 | 05:24 AM
JDMjdawg's Avatar
ttt
Old Jul 28, 2005 | 02:15 PM
JDMjdawg's Avatar
pm's replied...
Old Jul 28, 2005 | 05:50 PM
JDMjdawg's Avatar
up
Old Jul 29, 2005 | 09:05 AM
JDMjdawg's Avatar
bump
Old Jul 29, 2005 | 04:43 PM
KiddEng's Avatar
Old Jul 30, 2005 | 01:53 AM
JDMjdawg's Avatar
Default Re: GSR brakes/conversion, Brembo, Si master cylinder and prop vavle, steel braided lines (KiddEng)
pm'd
