B16 Water Pump??
Old Jul 24, 2005 | 07:39 PM
Swapped_EG's Avatar
Default B16 Water Pump??
I have a JDM b16 SIR II in my eg. I would like to upgrade my water pump. I was thinking either ITR or GSR. Anyone know which would be the best, or would it be the same as stock b16???? and what else i would need to do if anything to make one of those water pumps fit?? thanks
Old Jul 24, 2005 | 10:44 PM
Pondus's Avatar
Default Re: B16 Water Pump?? (Swapped_EG)
This has been covered many times before, but I can do a repeat : ALL B-series VTEC water pumps are the same.
Old Jul 25, 2005 | 06:13 AM
Lil Corb's Avatar
I'm pretty sure the amount of teeth on a b18c1 or c5 is different because of the length of the timing belt. So if you get a gsr pump you would have to use a gsr timing belt. Someone else can chime in.
Old Jul 25, 2005 | 07:18 AM
mmuller's Avatar
Mad Scientist
Default Re: B16 Water Pump?? (Pondus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pondus &raquo;</TD></TR><TR><TD CLASS="quote"> B-series VTEC water pumps are the same.</TD></TR></TABLE>
22t vs 19t for the non vtec
Old Jul 25, 2005 | 12:45 PM
Swapped_EG's Avatar
well mister repeat thanks for the wrong info. all b-series isn't the same. i knew ls and b16 for example are different. what i was trying to figure out is if the gsr or itr is the same?????? anyone know the correct answer for sure???? and thanks to the other guys for correcting mister know it all.
Old Jul 25, 2005 | 05:53 PM
mmuller's Avatar
Mad Scientist
Default Re: (Swapped_EG)
b16 is the same as b18c.
as per b-series, there only 2 different kinds; one for a vtec motor and the other for a non
Old Jul 25, 2005 | 05:57 PM
Lil Corb's Avatar
Default Re: (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">b16 is the same as b18c.
as per b-series, there only 2 different kinds; one for a vtec motor and the other for a non</TD></TR></TABLE>
are you sure? because on a lsvtec build you if you go with b18c water pump you would need a b18c timing belt. now if the thread starter went with the b18c pump the b16 timing belt wouldn't work. someone correct me if I'm wrong.
Old Jul 25, 2005 | 06:03 PM
Lil Corb's Avatar
EDIT: after quick search on good old H-T found if you use 22t pump you need any vtec timing belt.
Old Jul 25, 2005 | 06:08 PM
airshifter's Avatar
Default Re: (Lil Corb)
lsvtec uses an ls belt or a gsr belt depending on which water pump you use
ls pump = ls belt
b16/itr/gsr pump = gsr/itr belt
b16/itr/gsr pumps all have the same part number
b16 belt is for a block of a different height than ls or gsr/itr belt
Old Jul 25, 2005 | 06:09 PM
Lil Corb's Avatar
Default Re: (airshifter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by airshifter &raquo;</TD></TR><TR><TD CLASS="quote">lsvtec uses an ls belt or a gsr belt depending on which water pump you use
ls pump = ls belt
b16 belt is for a block of a different height than ls or gsr/itr belt</TD></TR></TABLE>
good stuff, that's what I was trying to say.
for reading my mind
Old Jul 25, 2005 | 08:16 PM
RMS's Avatar
RMS
there are early and late B16/B18c water pumps. same number of teeth but the late part number doesn't have alignment dowels for where it mounts to the block. they are interchangeable for all intents and purposes, however.
Old Jul 26, 2005 | 03:16 PM
Swapped_EG's Avatar
i appreciate the info guys, but the question stil remains will a gsr or itr water pump have any benefit over a stock b16???
Old Jul 26, 2005 | 03:37 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Swapped_EG &raquo;</TD></TR><TR><TD CLASS="quote">i appreciate the info guys, but the question stil remains will a gsr or itr water pump have any benefit over a stock b16???</TD></TR></TABLE>
NO
capish?
Old Jul 28, 2005 | 01:56 AM
Pondus's Avatar
As I said in my reply ^^^^^^
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pondus &raquo;</TD></TR><TR><TD CLASS="quote">This has been covered many times before, but I can do a repeat : ALL B-series VTEC water pumps are the same.</TD></TR></TABLE>
Old Jul 28, 2005 | 01:05 PM
Swapped_EG's Avatar
well that don't help much coming from the guy who didn't know there was a difference in dohc vtec and non- vtec water pumps. but thanks for trying.
Old Jul 28, 2005 | 03:16 PM
Pondus's Avatar
For the third time, my statement is that all VTEC pumps are the same, so if you use a B16, GSR or ITR pump it's the same piece. Yes I know the Non-VTEC pumps are different but that was not what you asked and I answered your question, maybe you need to actually read what people write next time around
Andrewvtec
Jan 21, 2011 12:23 PM
1995Civiccx
Northeast (Sales)
Sep 21, 2010 05:57 PM
untitled
Jul 25, 2003 11:51 AM
built562
May 4, 2003 07:27 PM
getgot2
Dec 22, 2002 12:54 PM
