b16a with LSD tranny...tranny fluid change question!!!!!!
ok well i was told that the LSD trannys need the fluid changed as often as the oil...so i was wondering where exactly is the filler hole and the drain hole....also how much fluid should i add back in after its drained all out. Also should i just put the OEM Honda fluid back in or does anybody recommend a different type? Thanks any help would be great.
