How do you tighten the emergency hand brake on a 2001 civic?
Old Jul 24, 2005 | 05:54 PM
spartan417's Avatar
Default How do you tighten the emergency hand brake on a 2001 civic?
Hi! I was just wondering if anyone knew how to tighten the emergency hand brake on a 2001 civic? I was told that it wasn't difficult at all and I figure I'd rather do it myself than take in for service. Thanks!
Old Jul 26, 2005 | 08:01 AM
djmota's Avatar
Default Re: How do you tighten the emergency hand brake on a 2001 civic? (spartan417)
pull off the center console the adjustment is at the bottom rear of the console.
Old Jul 26, 2005 | 07:44 PM
spartan417's Avatar
Default Re: How do you tighten the emergency hand brake on a 2001 civic? (djmota)
How do I go about detaching the center console? How many screws are securing the console to the car?
Old Jul 27, 2005 | 04:27 PM
spartan417's Avatar
I found out how to remove the center console. Thanks again for your response to my post.
Old Jul 28, 2005 | 08:32 AM
coupe99vtec's Avatar
yea if u have racing seats take them out, if u want to work with a pit more space get a ratchet and a 17 or 19 mm bit to take that retarded armrest off. pop off the 2 front little clips, and tear down the trim panels up top next to teh shifter (righ over the corner) slide both seats forward if their stock and at the bottom corners there are screws, there are also 2 screws up from where u took the panel cover things off. now get a realm skinny flat screwdiriver and a shirt and wedge in right behind the shifter in that little cap, now that little cneter part will come out and theres 2 more screws under there, take those out, no life the console from the back so it unhooks from the upper console in the from and pulll it out backwards. at the botton you will see 2 cables coming fomr theing back go into like a metal bar, and one going out from there, behyind that 1 cable there will be a 10 mm nut that you need to turn. I have mine tightened where if i put my car in D (its auto) and pull the brake up 2 clicks it doesnt go anywhere.
goodluck, and get like 2-3 beers for the job, lights are prefered, you dont want to start getting aggravated when ur putting a honda back together while ur drunk, lol, so grab a few smokes too
BLU BY U
Acura TL, RL & ZDX
Aug 12, 2008 10:06 AM
HaadkoeVTEC
Aug 17, 2002 05:56 PM
whagkangmakulet
17
Nov 22, 2001 01:23 PM
