Another "here's my setup and times thread" 203whp 2300 lbs w/ driver
Old Jul 24, 2005 | 05:51 PM
rjay8604's Avatar
Default Another "here's my setup and times thread" 203whp 2300 lbs w/ driver
Well I ran my EF at the Honda-Tech nopi nationals this weekend. It was fun getting to learn how to drive. The setup is a 91 EF hatch 2300lbs with me in it, 203whp. Bone stock suspension, remington all season tires on fat fives. I started pretty damn shitty at midnight madness.
First time ever running the setup:
60'= 2.681 1/4= 14.961@98.66 missed 3rd
later that night got down to a 14.5.
Next day best at nopi during open session:
60' = 2.437 1/4= 14.127@101.35
So tell me how bad i suck. No really though comments appreciated.
Modified by rjay8604 at 10:19 PM 7/25/2005
Old Jul 24, 2005 | 06:42 PM
Race Egr's Avatar
Default Re: Another "here's my setup and times thread" 203whp 2300 lbs w/ driver (rjay8604)
With that power/weight combo u should be running low13's high 12's practice is key. Also try using some slicks and maybe do some suspension work
Old Jul 24, 2005 | 09:00 PM
FaStTeg's Avatar
get slicks or atleast some better tires on that thing to get ur 60's down and the times will drop the 101mph sounds good though
Old Jul 24, 2005 | 10:22 PM
rjay8604's Avatar
Default Re: Another "here's my setup and times thread" 203whp 2300 lbs w/ driver (FaStTeg)
yeah. I am wondering if a lower 60 ft will also result in a slightly higher MPH. I know usually the best ET results in a slightly lower mph but the relationship between the two is tricky.
Old Jul 25, 2005 | 06:56 PM
dester223's Avatar
Man, I missed a ton of people at St. Louis this weekend. I really wished I would have known about the midnight madness thing. I would have shown up for that and had some fun
And about your setup. Get some slicks and suspension work. What were your 60 foot times?
Old Jul 25, 2005 | 07:21 PM
rjay8604's Avatar
Default Re: Another "here's my setup and times thread" 203whp 2300 lbs w/ driver (dester223)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dester223 &raquo;</TD></TR><TR><TD CLASS="quote">Man, I missed a ton of people at St. Louis this weekend. I really wished I would have known about the midnight madness thing. I would have shown up for that and had some fun
And about your setup. Get some slicks and suspension work. What were your 60 foot times?</TD></TR></TABLE>
2.4's yeah they suck.
Old Jul 26, 2005 | 05:58 AM
smokey2.0's Avatar
hey add another 50lbs to it, and come to moroso on the 20-21 of august for the nhra event. you can run the street stock class, full interior full exhaust, street tires. if you get your 60' times in the 2.0-2.2 range, you'll be running high to mid 13's!
Old Jul 26, 2005 | 12:37 PM
91integraLSVTEC's Avatar
Default Re: Another "here's my setup and times thread" 203whp 2300 lbs w/ driver (smokey2.0)
i made the same power with my ls/vtec with oem bottom end. get some traction bars. gutt the interior and get some slicks. dont get get 13x8 as it will dropp your mph get bigger slicks. i ran 12.9@104mph open diff in my da chassis. you can do practice makes perfect
Old Jul 26, 2005 | 03:42 PM
rjay8604's Avatar
Default Re: Another "here's my setup and times thread" 203whp 2300 lbs w/ driver (91integraLSVTEC)
Wow, good time with the DA. What the hell is wrong with me. Yeah i think i have quite a bit of power let in the motor. And a lot more potential in the quarter. I wanna try these M&H DOT race tires, like slick but street legal and damn near as good as slicks. I'm hoping i can get high high 12's evetually with only the 203whp. Then when i get up to 215-220whp i'll see if i can get in the 110mph range.
Old Aug 2, 2005 | 10:55 PM
rjay8604's Avatar
Well I ran again today at a test and tune. I didn't improve very much. I changed a few things. Added passenger seat (30 lbs), went with a full tank (last time it was about a 1/4 tank), switched front tire setup to 14" azenis on steelies.
Best tonight:
60' = 2.287
1/8 = 9.203
1/8 mph = 78.63
1/4 = 14.099
1/4 mph = 100.87
It seems like for my trap speed i am doing pretty decent. I would think 14.0 at 100mph is pretty decent. My issue is i think my MPH should be better, only 2300lbs with driver, fully tuned making 203whp, what gives? I guess the stock suspension hurts me but really only on the launch anyways. Hmm input and assistance appreciated.
Modified by rjay8604 at 3:30 AM 8/3/2005
Old Aug 2, 2005 | 11:58 PM
smokey2.0's Avatar
with a set of 13x8x22" slicks, you'll have no problem hitting 13.5! but if you get a little more practice, with the azenis you should hit 13.8-13.9! i use to run 13.1@103 with 14" azenis a while ago, i think i was running them between 14-16 psi! good luck! btw come to moroso on the 20-21 and run in the street stock class, you meet all the requirements!
Old Aug 3, 2005 | 02:36 PM
ChaseIntegra's Avatar
I think we all agree you have a 13 second car easily, just need some driving skills
Old Aug 3, 2005 | 05:34 PM
rjay8604's Avatar
Default Re: Another "here's my setup and times thread" 203whp 2300 lbs w/ driver (ChaseIntegra)
But it seems to me that even if i can get 13's, i should be trapping a lot better. I make about the same power as an s2000, yet my car weighs about 900lbs less, yet i run the same mph as one. Its just kinda disappointing.
Old Aug 20, 2005 | 01:16 AM
rjay8604's Avatar
So i broke into the 13's tonight. My 60' times are still pretty lame, but i was pretty happy my mph went up a tad. This time the changes were, a Koyo alum. radiator (used to overheat) , reset my intake cam gear to +6 (like it was during dyno tune), and put some VX wheels and tires on the back (30lbs savings over fat fives).
Best:
R/T: I don't really worry about this becuase i focus on launching.
60': 2.322 (tire pressure 30psi)
330: 6.042
1/8: 9.093 @ 80.52
1/4: 13.900 @ 101.99mph
I was very happy to break 13's. I wanna get my traps into the 104-105 range eventually. It'll take some more power and some better weather.
beaver
Mar 31, 2006 04:36 PM
LSVTEC 91 Civic
14
Apr 22, 2005 03:57 PM
Judd
Oct 29, 2004 04:36 PM
Jockobo
Nov 8, 2002 05:57 AM
b16_incarnate
16
Oct 23, 2002 01:36 PM
