Cali drivers....... wats ur setup?
Old Jul 24, 2005 | 03:53 PM
pooMan's Avatar
Default Cali drivers....... wats ur setup?
does anyone in cali drive with a turbo or engine swap setup? if so how do u get it by smog check? (i was deciding wether to get the turbo or the swap for my 6th gen accord.) *damit* i hope i dun get flamed........ i hope this is an okay question...... thnx honda-tech.com community. great site by the way (hella helpful)
Old Jul 24, 2005 | 11:07 PM
raceACCORDingly's Avatar
take it off every 2 yrs or find a hook up
Old Jul 24, 2005 | 11:42 PM
goowakjai
Guest
Posts: n/a
Default Re: Cali drivers....... wats ur setup? (pooMan)
maybe if u look artound hard enough u'll find a carb approved turbo kit?? and i dunt see why a H22 wuidnt pass smog regulations -_-a...i cud understand a B20
Old Jul 25, 2005 | 12:52 AM
The_Todd's Avatar
Farts in the shower
Default Re: Cali drivers....... wats ur setup? (goowakjai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goowakjai &raquo;</TD></TR><TR><TD CLASS="quote">maybe if u look artound hard enough u'll find a carb approved turbo kit?? and i dunt see why a H22 wuidnt pass smog regulations -_-a...i cud understand a B20 </TD></TR></TABLE>
Its not that it won't, its that california doesn't see the reason for a swapped motor so they will fail you unless you get an exempt sticker or another sticker (forgot what its called). California is very strict on their inspections portion (unless you have a hook up).
I haven't had to deal with it first hand I am just giving input based off of what others on this board have said.
Old Jul 26, 2005 | 12:00 AM
goowakjai
Guest
Posts: n/a
Default Re: Cali drivers....... wats ur setup? (.ken)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .ken &raquo;</TD></TR><TR><TD CLASS="quote">Its not that it won't, its that california doesn't see the reason for a swapped motor so they will fail you unless you get an exempt sticker or another sticker (forgot what its called). California is very strict on their inspections portion (unless you have a hook up).
I haven't had to deal with it first hand I am just giving input based off of what others on this board have said.</TD></TR></TABLE>
aww man...cali sucks!...why is it our nations tuner capitol?!?!
88rex_zc
Sep 27, 2008 08:43 PM
OutlawCL
Nov 8, 2005 01:15 PM
TheNasty0ne
May 23, 2004 01:31 PM
monsterb18b
Aug 28, 2003 04:59 PM
dingusjt
Oct 7, 2002 04:54 PM
