Question on USDM ITR Header....
Old Jul 24, 2005 | 03:27 PM
MansuDC2's Avatar
Default Question on USDM ITR Header....
Can I use a USDM Integra Type-R Stock Header or a DC Sports USDM Type-R Header in my 97 Integra RS w/ B18B1 motor? I know I can fit the JDM DC ITR header but hat about the USDM one? Anyone used the USDM ITR header instead of the JDM ITR header?
Glenn
Old Jul 24, 2005 | 05:57 PM
Padawan's Avatar
Darth ModerVader
Default Re: Question on USDM ITR Header.... (MansuDC2)
Yes, it will bolt right on. However, the stock ITR exhaust manifold doesn't flow terribly well, and probably won't be worth the cost or effort to install it.
Old Jul 24, 2005 | 08:51 PM
MansuDC2's Avatar
Default Re: Question on USDM ITR Header.... (Padawan)
Well, I know the USDM ITR header has a 2.25" collector compared to the JDM ITR with a 2.5" collector, I want to run the USDM one because I don't want to end up damaging the header sice the JDM ITR one hangs really low, and I wanna run 2.25" piping instead of 2.5" , What if I used a DC Sports USDM Type-R header would that be better, and my motor is DOHC Non-Vtec so I wouldn't want to run that big of a piping size like 2.5". Doesn't the USDM Type-R header flow better than a Dc Sports Header made for the LS? What would you reccomend?
Glenn
Old Jul 25, 2005 | 02:21 PM
Padawan's Avatar
Darth ModerVader
The USDM ITR exhaust manifold has a 2" OD collector, not 2.25". The DC Sports header would be a better option, but you can find 4-2-1 headers that offer greater performance without sacrificing ground clearance. The choice really depends upon your budget and your plans for the setup.
Old Jul 25, 2005 | 02:26 PM
JDM-EJ1's Avatar
Yes, it will bolt up 100% fine.
Old Jul 26, 2005 | 08:40 AM
MansuDC2's Avatar
Default Re: Question on USDM ITR Header.... (JDM-EJ1)
Thanks.
Old Jul 26, 2005 | 10:39 AM
dFreezy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">but you can find 4-2-1 headers that offer greater performance without sacrificing ground clearance</TD></TR></TABLE>i think you were referring to 4-1 headers that have worse ground clearance most 4-2-1 fit closer to the oil pan
Old Jul 26, 2005 | 01:36 PM
Padawan's Avatar
Darth ModerVader
Default Re: Question on USDM ITR Header.... (dFreezy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dFreezy &raquo;</TD></TR><TR><TD CLASS="quote">i think you were referring to 4-1 headers that have worse ground clearance most 4-2-1 fit closer to the oil pan</TD></TR></TABLE>
Not sure what you mean. I was explaining that there are 4-2-1 headers that will perform better than the the DC Sports header (either 4-1 or 4-2-1 version) while still maintaining the ground clearance that the original poster was concerned about.
Old Jul 26, 2005 | 03:01 PM
MansuDC2's Avatar
So DC Sports is out of the question, i'm thinking of the Edelbrock 2-piece Header since they make a replacement down pipe for racing that has a 3" exit dumping out to the ground, w/ no cat attached. Don't got money for like the SMSP or Comptech, or Kakimoto and such.
Glenn
98B18C1
Mar 6, 2004 01:52 PM
X2BOARD
Sep 5, 2003 02:13 AM
exactvox
Jun 30, 2003 11:48 PM
Frito1
Feb 23, 2002 08:10 AM
