zc tranny fit into d16
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deemeetree »</TD></TR><TR><TD CLASS="quote">The ZC should be cable. If you want to avoid headaches, find a hydraulic transmission.</TD></TR></TABLE>
Yeah, not worth the trouble.
Im having some trouble with my 91 crx si.. I put in a shunk stage 2 clutch and for some reason the gears go in when the car is off.. But as soon as trun on the car it will not go ino gear at all.. I check if the pressure plate was the wrong way... I adjusted the clutch cable idk what els to do or look for....I put a d16a motor and the transmission is a zc 91 L3 tranny.. Any ideas.. Thanks
Please don't bump 11 year old threads. Instead post in the Introductions section a greeting and some replies to get past the 5 post thing to be able to create your own thread here.
Thank you.
Thank you.
xotic_crx
May 20, 2007 08:53 PM
sloweredcivic
Oct 1, 2003 11:58 AM
