Skunk2 Intake manifold
Old Feb 18, 2002 | 03:13 PM
JdoggsGSR's Avatar
New User
Default Skunk2 Intake manifold
I have a quick question can i use the the GSR CAI wit the skunk2 intake manifold???
Old Feb 18, 2002 | 03:28 PM
GSR2001's Avatar
Default Re: Skunk2 Intake manifold (JdoggsGSR)
Good question!!!!!!
Old Feb 18, 2002 | 03:33 PM
nfn15037's Avatar
Default Re: Skunk2 Intake manifold (GSR2001)
Im pretty sure no, since the GSR IM has the TB sitting so low, while the S2/ITR TB sits higher, hence the extra bend in GSR intakes.
[Modified by nfn15037, 4:33 PM 2/18/2002]
Old Feb 18, 2002 | 03:51 PM
JumbosGS-R's Avatar
New User
Default Re: Skunk2 Intake manifold (nfn15037)
No you can't. You can either buy the LS AEM CAI or a Type R one. Go w/ the Type R one b/c it's bigger. And by bigger I mean wider.
Old Feb 18, 2002 | 06:14 PM
JdoggsGSR's Avatar
New User
There is no way to make this work wit the GSR CAI??? what if i bend it???
Old Feb 18, 2002 | 06:23 PM
Spyderwebab's Avatar
Well, hey if you can bend it got ahead. But I believe AEM designs there intakes to have the best bends for airflow. Your just setting yourself up for loss in power. Yea I was pretty pissed too when I found out I had to switch to the ITR intake. But hey its worth it. I got rid of that POS bypass valve, and got a bigger intake.
Old Feb 18, 2002 | 07:09 PM
Black DC2's Avatar
Default Re: Skunk2 Intake manifold (Spyderwebab)
i cut mine and i bough the the thing that doesn't let the water get in to the manifold and it work really good for me
Sorry i forgot the name
Old Feb 18, 2002 | 08:14 PM
Evil DOHC's Avatar
Default Re: Skunk2 Intake manifold (mighty goku)
You can make it work with an extra coupling, clamps and a saw saw. It won't look perfect but it will do the job. Personally I rather sell the gsr aem and purchase a new type r aem so it will look perfect and fit right.
EVIL
Old Feb 18, 2002 | 08:41 PM
nfn15037's Avatar
Default Re: Skunk2 Intake manifold (Evil GS-R)
Hey evil, do you have a S2 mani on your GSR? If so, how do you like it, im hearing mixed impressions from people.
Old Feb 19, 2002 | 02:05 AM
HKxBlur's Avatar
dont' think of it as an s2 mani, think of it as an LS, SI, ITR motor with the single-runner manfold and trying to put a GSR intake on that..
To answer your question, YES it will work.. There will be a 'hump' up top since the gsr manifold's throttle body sits lower.. Hood clearance wasn't an issue on my EK, however, I'm not sure if it is on the DC chassis.. The intake will not mount to the shock tower like it used to, so it will have to be 'extended' in order for it to bolt-up, but my suggestion is to NOT do it at all.. If u have to roll it around for a couple weeks so u can find a new/used LS/ITR intake, then i guess it's okay..
[Modified by HKxBlur, 11:06 AM 2/19/2002]
Old Feb 20, 2002 | 02:21 AM
C4wrx's Avatar
Default Re: Skunk2 Intake manifold (HKxBlur)
i got it to work, i just cut the mounting piece off and jammed in into the fender area
Das Nuge
Nov 11, 2004 12:51 PM
undagroundrican
Aug 3, 2004 08:44 PM
redteg1
Jan 6, 2002 06:38 AM
MacLeanQuinn
Oct 22, 2001 06:32 PM
Cyrio
Aug 13, 2001 12:21 PM
