Which ECU in 92 JDM SiR?
I have a 92 SiR here in Japan that I will be ripping apart to send back as parts to the states, and I am wondering what ECU it has? Also since it's a OBD 0, what will all be involved in my EG swap when I get it back? Thanks in advance!
if the VIN starts with this JHMEG65 then it's a SiR II which is OBD1 and it came with a P30.
To do the swap into an EG in the states? It bolts right in using everything from the SiR.
try to get the ECU with the motor, it will be a p30 ecu, or you can try to find a OBD I usdm del sol p30 (which is hard to do) or you can get an OBD I p28 and get it chipped
good luck
good luck
markleavey
Dec 5, 2002 09:42 AM
