Oil leak PROBMLEM!
so i have this oil leak, it seems like it coming from the top side if my oil pan, but i keep getting leakage from my trans. i thought maybe it was hitting my flywheel and splashing inside the casing of the trans (i dont have a flywheel gaurd)
my ? is...
is there anyway it could be coming from inside my trans case and in the clutch area? i didnt see any cracks or anything when i pulled it out. maybe around the input shaft?
i know my rear main seal is fine, its a 2000 motor with like no miles on it! plus when i unbolt the clutch it's dry around it.
please help!
my ? is...
please help!
see, thats what i was thinking, but it leaks out of the clutch area the whole time, i dont see it runing down the oil pan, thats what got me thinking... maybe a gasket around the input shaft?
inputshaft bearing maybe?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwissChEz82 »</TD></TR><TR><TD CLASS="quote">Your problem is probably your main seal.</TD></TR></TABLE>
thats what some one else said, but the motor i have in the is out of a very low mile 00'. when i pulled the flywheel off there was no oil under neeth it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Contender25 »</TD></TR><TR><TD CLASS="quote">Not too sure any anything else man, maybe you got a oil somehwere else, im not really gonna know unless i took a look at it, maybe you can post a pic or somethin.
see, i put it back together already, thinking i fixed my problem, but i didnt...
come on up and i'll pull her right out
i wish i could figure it out...
</TD></TR></TABLE>see, i put it back together already, thinking i fixed my problem, but i didnt...
