cleaning inside of headlights?
When I turn on my lights, the inside of the headlight casing looks dusty or something... is there a way to clean the glass on the inside or do i need to get all new headlights?
thanks
thanks
there a nice thread in the useful links archive about baking the headlights. if you bake them, open them up, im sure there is some plastic compound you can use to clean them.
I hate everything
Yeah you can bake them, or if you get a heat gun, you can split the seal that way as well. If you have the, i believe June issue of Honda Tuning, they have an article about it. I believe for retrofitting for HID's but show a good method to crack that bitch open.
Good luck.
Good luck.
I would suggest 'baking' the headlight. Which is pretty much putting your headlight in the over about about 225 degrees for a couple of minutes and then gently prying it apart with a flathead screwdriver, or some flathead object.
At this point, you can clean your headlights. To reseal, get some caulk and reseal it good to make sure no moisture gets in.
