Loose Shifter While In Gear
Old Jul 23, 2005 | 07:18 PM
oni3's Avatar
Default Loose Shifter While In Gear
When I'm in gear, doesn't mater which, the shifter is loose like it's in neutral. I've had this problem ever since I did my motor swap. Car is a '00 EX, B16A2 motor swap, we did the EM1 shift linkage when the swap was done. I just put in some ES shift bushings and no help.
Old Jul 23, 2005 | 07:19 PM
BROKE.eg's Avatar
Default Re: Loose Shifter While In Gear (oni3)
are you using a roll pin in the shift linkage or just a bolt? i had a bolt in mine for a ghetto quick fix till i got a roll pin. and it was sloppy as **** in gear.
Old Jul 23, 2005 | 07:26 PM
oni3's Avatar
Default Re: Loose Shifter While In Gear (BROKE.eg)
Never thought to check for something like that. I'll have to see, thanks for the advice.
rwlangdale
Feb 12, 2008 11:15 AM
bOOsTiNSoHcVtEc
May 21, 2003 03:25 PM
ScottEK
16
Jan 16, 2003 09:31 PM
