omg finally a new suspension!
Fortune Cookie Member
2 more pics on page 2
a
what could it be?
maybe someone can tell from the top side?
omg if you guessed Tein SS you were correct! (yes, i am aware that that was corny
these are the two pairs of fronts. looks to be quite different...
i still have some height/dampening adjustment to do (specifically the rear needs to come up a lil and the front needs to be softer) the front is as low as it will go...
heres the front wheel gap
heres the rear wheel gap
heres the universal measurement tool under the front mudguard
heres the universal measurement tool under the front lip at the lowest point
: Prepares for the inevitable :
Modified by crdcz03 at 7:29 AM 7/25/2005
a what could it be?
)these are the two pairs of fronts. looks to be quite different...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber »</TD></TR><TR><TD CLASS="quote">how does it ride?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber »</TD></TR><TR><TD CLASS="quote">the thing is, you've already maxed out all the threads on the shock body...how does it ride?</TD></TR></TABLE>
why would it matter if i have it on the lowest part of the shock? they're made to be adjustable like that...
it rides better than my old stuff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ya »</TD></TR><TR><TD CLASS="quote">those ludes, even though they don't LOOK that low from the front bumper, the body rides low. careful
lol, it is a common misconception. all the hatches at work are "lower" than my car but they're roof's are higher
i'm not trying to start a huge argument...but with you having the perch all the way down like that, you're sacrificing a lot of suspension travel...just a heads up...the car looks good how it sits tho...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber »</TD></TR><TR><TD CLASS="quote">i'm not trying to start a huge argument...but with you having the perch all the way down like that, you're sacrificing a lot of suspension travel...just a heads up...the car looks good how it sits tho...</TD></TR></TABLE>
explain
explain
your coilovers are only single perch height adjustable...meaning....every time you raise/lower the perch you're affecting the stroke of the shock.....
the coilovers that you can adjust the height without affecting suspension stroke feature upper and lower perches for height adjustability..where you bring the bottom perch up to lower the car...
if you need a few more inches lower on the car, i suggest you get a set of pillowball mounts from tein....that will give you about an 1"-1.5" lower than the stock pillowball mounts...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber »</TD></TR><TR><TD CLASS="quote">your coilovers are only single perch height adjustable...meaning....every time you raise/lower the perch you're affecting the stroke of the shock.....
if you need a few more inches lower on the car, i suggest you get a set of pillowball mounts from tein....that will give you about an 1"-1.5" lower than the stock pillowball mounts...</TD></TR></TABLE>
so you're saying i should raise it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">More expensive suspension components on a car that will never use it. We salute you, Mister Overpriced Suspension Components Installer
.</TD></TR></TABLE>
as long as im driving it, ill be using it.
edit: btw, $400 for a slightly used suspension is hardly overpriced.
.</TD></TR></TABLE>as long as im driving it, ill be using it.
