cams in ls vtec
Old Jul 23, 2005 | 03:27 PM
civicswap's Avatar
Default cams in ls vtec
I have a ls vtec, oversized jdm itr pistons and gsr head, the compression is 11.6:1. I was wondering which cams would be good for my setup. I was thinking buddy club stage 3+ or 4 or maybe m22. What do you suggest?
Old Jul 23, 2005 | 03:55 PM
Yambor's Avatar
Default Re: cams in ls vtec (civicswap)
whats your goal , and where do you want your powerband to be? what tranny are you using?
Old Jul 23, 2005 | 03:59 PM
civicswap's Avatar
Default Re: cams in ls vtec (JH4DC4-2GSR)
I'd like to have close to 200hp. I want mid range power, gsr tranny
Old Jul 23, 2005 | 05:06 PM
PURPLETERROR aka BIGMATT's Avatar
bc3+ if you want good midrange, skunk pro1 if you want good midrange and top end. Make sure you upgrage your springs and reatiners also. Hopefully you have arp rod bolts.
Old Jul 23, 2005 | 07:14 PM
Yambor's Avatar
Default Re: cams in ls vtec (PURPLETERROR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR &raquo;</TD></TR><TR><TD CLASS="quote">bc3+ if you want good midrange, skunk pro1 if you want good midrange and top end. Make sure you upgrage your springs and reatiners also. Hopefully you have arp rod bolts.</TD></TR></TABLE>
Old Jul 23, 2005 | 08:43 PM
civicswap's Avatar
what about the bc4?
Old Aug 18, 2005 | 07:25 AM
drunknmonkey18's Avatar
i wanted to go with bc5's with bc springs and retainers but i heard that if the lobs are too big there might not be enough clearence and the pistons might hit the valves?
do you know if the bc5 will fit with enough clearence
mustwonder7
Apr 19, 2009 06:03 PM
dc4teg95
Jun 29, 2007 12:43 PM
RATED EG
Jul 12, 2005 11:34 PM
bens_redeg
13
Apr 1, 2004 05:33 AM
lsvtecrocket
Dec 1, 2003 02:30 PM
