HELP-All the sudden car won't start??? pump primes, then silence...
Old Jul 23, 2005 | 02:56 PM
Autoworks's Avatar
Default HELP-All the sudden car won't start??? pump primes, then silence...
I just drove my car 2 days ago, and everything was perfect. I went out today to drive it. I turned the key, let the pump prime as usual, turned all the way to crank it and ditto...dead silence. No clicking, starter did nothing. So I pulled the starter out, took it to get tested and it came up on the computer perfectly fine. It's like I am turnong the key and something in between that action and the starter is not connecting...but 2 days ago it was fine. Any help/info is greatly appreciated.
Everything works up until you try to crank it, no cel, all the dashlights work, clock, headlights all work. Battery is fine (Odyssey P680). I checked the fuses, none were blown. What else?
Old Jul 23, 2005 | 03:53 PM
Autoworks's Avatar
Default Re: HELP-All the sudden car won't start??? pump primes, then silence... (Autoworks)
bump
Old Jul 23, 2005 | 04:13 PM
Autoworks's Avatar
****, finally progress. I just went out and quadroople checked my grouns and they are all fine. I sit in the car and ponder a bit and noticed a little blue piece of something laying on the floor by my pedals. Looks kinda like candy. Anyway I get down there and look up under the dash but see nothing, I ran my hand all the way up my clutch and knocked off another piece of whatever the blue/gray candiesh thing was. I felt a switch above the clutch. I held the switch in with one hand and turned the key and the car crunk fine. Now my question is what was that broken piece that goes at the top of the pedal assembly? It pushed the button in while cranking, now its now its broken and not there at all? What do I need to do or does anyone know what its called?
Old Jul 23, 2005 | 04:31 PM
NewtoHonda's Avatar
Its the little plastic piece that goes inside the top of the pedal to hit the clutch switch. I did this to brake pedal on my sisters integra. What I did was:
1. Cut a little piece of firmika a little bit bigger than the hole in a rectangular shape.
2. put some super glue on there and held it for one minute.
After that I made sure it was on there good and tested it. I'm not sure if this will work with the clutch pedal. But I think its worth a try. And you don't have to use firmika. I'm sure most hard flat plastics or some fiberboard work as well. Let me know if this works
Old Jul 23, 2005 | 05:23 PM
Autoworks's Avatar
Default Re: HELP-All the sudden car won't start??? pump primes, then silence... (NewtoHonda)
I took a short screw, nut and 2 washers. Stacked the washers and put the screw thru the hole at the top of the clutch, tightened it down and it works perfectly fine. The head of the bolt now pushes the button down.
Do you think I should just leave it like this or try to get another OE part.
I guess A good thing is this doubles as an anti-theft device. When I leave for extended periods, I can just take the bolt back out, the car definately can not be started without it.
bsballboyjk
Mar 17, 2008 11:44 AM
Autoworks
Jul 23, 2005 06:20 PM
deftones0817
Jul 14, 2005 08:17 AM
tommymoose
May 18, 2005 03:40 AM
jermothedrunk
Jun 30, 2002 08:29 PM
