Pros/Cons: Eibach Spo vs Pro
Old Feb 18, 2002 | 01:37 PM
pub's Avatar
pub
Default Pros/Cons: Eibach Spo vs Pro
Was rather interested in the Eibach springs and just came back with an unsuccessful search. If anyone has had experience with both springs, please post something. I autocross about once a month/2months and am right now ridin' stock. Any help/recommendations would be nice.
Old Feb 18, 2002 | 01:52 PM
Calavera's Avatar
Default Re: Pros/Cons: Eibach Spo vs Pro (pub)
Not trying to be a jerk but I searched the word "eibach" under the archived topics and came up with more than 4 pages about the springs. I'm sure this topic has been talked about alot in the past.
Old Feb 18, 2002 | 05:36 PM
pub's Avatar
pub
Default Re: Pros/Cons: Eibach Spo vs Pro (Calavera)
..Yes, I also did a search on that - and no help. Reading into the posts - you can see. Just a bunch of jibber jabber.
Old Feb 18, 2002 | 05:44 PM
1fastGSR's Avatar
New User
I have the Eibach Prokit and I am VERY happy with them. Much better than stock and slighlty better than ITR springs, but I do not think they are meant for racing.
Old Feb 18, 2002 | 07:56 PM
vteg's Avatar
New User
I have the sportlines. I like them alot. They lower the car about .4 inches more than the sportlines. My only problem with them is the rear springs. I think they are too soft. At one of my favorite free exits, there is a bump. If I go to fast, I can hear the back bottom out and the tire scrub the inside of the wheel well.
Old Feb 18, 2002 | 08:30 PM
b18bvtec4drteg's Avatar
Pro kits are the way to go IMO the sportlines do lower ur car more and when I had those it needed a camber kit on the back. Yes the rear is too soft as stated above. If you X-cross look into some ground controls or skunk coilovers.
ps do get shocks when you swap them out also.
Old Feb 18, 2002 | 09:58 PM
Calavera's Avatar
Default Re: Pros/Cons: Eibach Spo vs Pro (b18bvtec4drteg)
After doing some searching myself, I decided to go with Eibach Prokits. Reason being that they lower 1.3~1.5" max which is what I wanted. So the Sportlines were not included in my choices. And if you lower more than 1.5" a camber kit was recommended and I didn't feel like spending extra money. Groupbuy or coximports.com has them for $190 which was cheapest I found ever.
Some people with a drop of 1.5"~1.8" said they were scraping everywhere. It really depends on where they live, but I live near Los Angeles so I knew I'd run into those problems.
Alternatives for the Prokit were the H&R Sport springs with drops 1.75" front and 1.5" back. Reason being that the Integra has a larger wheel gap in the front so lowering front and back equally would have made the rear appear lower than the front. So the manufacturer kept that in mind when they were making those. And they were cheaper. The cheapest I found were $149 from options auto salon.
Old Feb 20, 2002 | 12:49 PM
1fastGSR's Avatar
New User
Default Re: Pros/Cons: Eibach Spo vs Pro (vteg)
The Prokit are actually stiffer than the Sportline. I checked it out before buying my Prokits. I could not believe it. I guess the Sportline only drop the car more.
Old Feb 20, 2002 | 01:24 PM
GSRaCeRbOI's Avatar
i have the sportlines because i wanted a lower drop than the Pro-kits offered.. they handle pretty well along w/ my Koni adjustable sport shocks (yellows) but like the others said.. the rears are kinda soft.. i think the pro-kit actually has stiffer spring rates, but offers less of a drop.. overall im happy w/ my sportlines tho.. they havent sagged and still have very nice handling/road feel after a few years...
Old Feb 20, 2002 | 01:30 PM
ALF's Avatar
ALF
Default Re: Pros/Cons: Eibach Spo vs Pro (1fastGSR)
I've researched this before...*this is for the G3 Integra*
460F / 174-275R (progressive) - Sportline
331F / 125-194R (progressive) - Pro-Kit
[Modified by Dozed, 5:32 PM 2/20/2002]
Old Feb 20, 2002 | 01:35 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Pros/Cons: Eibach Spo vs Pro (Dozed)
So the Sportline lowers more, AND has higher spring rates. Then why do I hear people say the Pro-Kit's are better for performance? Looks to me like the Sportlines would be a better choice if you are willing to lower it that much.
I have H&R Sports, I like them pretty well so far, however the back end of my car STILL sits higher than the front, just like it did stock. I'm going to try setting my rear Konis to the lower spring perch and see how I like it.
[Modified by PatrickGSR94, 4:35 PM 2/20/2002]
Old Feb 20, 2002 | 01:54 PM
GSRaCeRbOI's Avatar
Default Re: Pros/Cons: Eibach Spo vs Pro (PatrickGSR94)
haha get a system w/ a large sub box.. i couldnt figure out why my rear sat a bit lower and my car looked a little tilted towards the back.. when me and a buddy redid my set up and had everything out the rear evened out Lolz..
btw.. did u fix that broken shock adjuster?
Old Feb 20, 2002 | 02:46 PM
ALF's Avatar
ALF
The rates I listed were from 8 months ago. They were derived from the approval of various members on this message board.
Old Feb 20, 2002 | 03:52 PM
1fastGSR's Avatar
New User
huh? That's is not what I was told!! I reaserched this 1 year ago before buying the springs. I do not have the number anymore, Tuan from superhonda did tell me that the Prokit had a stiffer spring rate!! Oh well!!
Old Feb 20, 2002 | 04:57 PM
IntegraGSR23's Avatar
Go for Comptech's cheaper then Eibach's
Comptech
Old Feb 20, 2002 | 05:17 PM
1fastGSR's Avatar
New User
Default Re: Pros/Cons: Eibach Spo vs Pro (IntegraGSR23)
they actually cost about the same if you look for a good deal on the Eibach. You can't go wrong with either one.
Old Feb 20, 2002 | 06:42 PM
BSQ's Avatar
BSQ
These spring rate are correct. When I was researching springs about 3 year ago, I consulted with Truechoice ( http://www.truechoice.com ) and they gave me the same spring rates listed above. Think about it, the Pro-kits lower ~1.5" and the Sportlines lower ~1.75". Therefore, if you have a lower drop then you will need a higher spring rate to prevent bottoming out of the suspension. HTH
Old Feb 20, 2002 | 06:47 PM
MrBite's Avatar
Default Re: Pros/Cons: Eibach Spo vs Pro (BSQ)
Just curious...For these the rates are much higher in the front, but racing springs are usually stiffer in the back...why is it so different? Just for ride quality on the street?
Old Feb 20, 2002 | 06:48 PM
AlphaKennyWun's Avatar
Eibach prokit will make your car 'look' like it is lower in the rear. Actually the drop is even and the front fender gap gives the illusion. I got the koni yellows...fixed that problem real quick.
Old Feb 21, 2002 | 02:34 PM
Muglit's Avatar
New User
Default Re: Pros/Cons: Eibach Spo vs Pro (SO3Burner)
I just got an email back from Eibach today and they said the spring rates are the same for the sportline(4.2040) and prokit(4020.140).
The rates they gave me are the ones listed in this tread as the ones for the prokit: 331.2F/125.6-194.2R.
Old Mar 6, 2002 | 07:28 PM
Muckman's Avatar
Moderator in Chief
Default Re: Pros/Cons: Eibach Spo vs Pro (Muglit)
Just for comparison... what is the stock spring rates for the GSR and ITR?
Old Mar 6, 2002 | 07:41 PM
Scary1109's Avatar
do you have any pics of your car? and can you explain what you you noticed with the back looking lower?
Thanks
Scott
Old Mar 6, 2002 | 08:49 PM
Integra97Zeke's Avatar
eibach prokit =
S_TWO_K
Honda S2000
17
Mar 9, 2008 03:58 PM
jdm37334
May 3, 2007 10:33 AM
crxaddikt
11
Apr 20, 2003 11:46 AM
