Stock D16 engine parts
I have the following parts left over from my D16 build and would like to find them a good home, most everything includes required bolts, etc. All parts have unknown mileage, shipping is extra
make me an offer if you don't like my prices...)
D16Y5 block - In very good shape. Been hot tanked, very clean. Includes lots of extra girdle bolts, rear seal assy (2), water pipe (2), breather box, Oil pan (kinda rough, but with turbo oil drain fitting), etc. $75
D16 crank - Journals in good shape, but grooves in the seal areas at each end. A good machine shop can re-sleeve these areas. Includes crank pulley, belt drive pulley, flywheel bolts. $25
Stock pistons & rods -Good pistons mounted to good rods. $25 for the complete set.
Water pumps - I have two of these! $10 for both.
Oil Pumps= Two of these, also. Includes the complete assy and housing with crank position sensor mounted. I haven't taken them apart. $10 for both.
Various engine mounts/brackets. $5 for all
Plastic front cover- 2 of these, with at least one set of bolts and one seal. $5
Stock flywheel and clutch with good life left. $20
Timing belt tensioners- two of these- with bolt and springs. $5
Or EVERYTHING for $130
I am in SoCal (Torrance)
email for more details, shipping prices, or photos. boostengineering@earthlink.net
I accept paypal at: boostengineering@earthlink.net
Thanks,
Brian
Modified by Beanbooger at 11:21 PM 7/23/2005
Modified by Beanbooger at 12:18 AM 7/24/2005
make me an offer if you don't like my prices...)D16Y5 block - In very good shape. Been hot tanked, very clean. Includes lots of extra girdle bolts, rear seal assy (2), water pipe (2), breather box, Oil pan (kinda rough, but with turbo oil drain fitting), etc. $75
Thanks,
Brian
