Upgrading Q?s!!!
What are the best Spark Plugs that i should be runnin on?
What ECU chip is recommended?
What is a good Short Shifter for good price?
Is Gas preffered for the higher Octane or does that matter?
oh god.
ngk
hondata
b&m or skunks but theyre a waste of $ imo
give the gas your engine needs. if it says use 87 dont use 91 unless you can afford it cuz it wont do ****. if your swapped or have high cr then use higher octane
ngk
hondata
stock plugs will do just fine
dont chip it (we're talking about a stock motor right?)
skunk 2 cause its made of steal not aluminum around $100
i usually run high octane cause i like my car i guess personal preference unless you got turbo or nitrous or high compression.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 »</TD></TR><TR><TD CLASS="quote">
give the gas your engine needs. if it says use 87 dont use 91 unless you can afford it cuz it wont do ****. if your swapped or have high cr then use higher octane</TD></TR></TABLE>
b&m shifter
87 octane
b&m shifter
87 octane
AllmotorJunkie
Jul 16, 2003 07:03 AM
