Post up ur 85x89 dyno charts!!
just as topic says. I wanna see what people are makin with 85mm bore and 89 stroke. Plz give brief discription of build. Thanks and have a good weekend!
Here is one from about 15 months ago ..
89x85 wiseco 8cc's
AEBS sleeves
RLZ GSR Head "stock valve size"
RLZ stage 3 cams
AnR header
Victor X Mani
BBK 70mm TB
89x85 wiseco 8cc's
AEBS sleeves
RLZ stage 3 cams
AnR header
Victor X Mani
BBK 70mm TB
want more horsepower from your head?.............
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAX_CFM »</TD></TR><TR><TD CLASS="quote">250 dur @ .050 .500 lift 102 cen
255 dur @.050 .470 lift 110 cen</TD></TR></TABLE>
enlighten us......
enlighten us......
Gimme about a week (maybe two) and I'll have Pandahatch's up...
89x85 Dart block, ~12.8:1 comp, ported B16 head, Sk2 Pro1, 50mm TWMs.
Did street tuning of low cam tonight... Thing is scary, even without vtec. Hope to make it to the dyno sometime late this week or early next.
I don't have a dyno graph but my drag car makes 256 and 165 ish.
85.5 mm pistons
89 stock LS stroke
Port Flow GSR head
14-1 Arias shelf pistons
Hy-tech Side Exit
Edelbrock Victor X manifold
RC 310 injectors
Skunk 2 stage 2 cams
Stock cam gears
Mugen Program P28
85.5 mm pistons
89 stock LS stroke
Port Flow GSR head
Hy-tech Side Exit
RC 310 injectors
Stock cam gears
Mugen Program P28
I have an 85X89, but have to put it in the car and tune it. I will post it up when i dyno tune it. but i might just street tune and datalog at the track.
12.8 compression
ported b16 head
aebs manifold
bored itr TB
BC4 cams
Custom header
12.8 compression
ported b16 head
aebs manifold
bored itr TB
BC4 cams
Custom header
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAX_CFM »</TD></TR><TR><TD CLASS="quote">One dyno sheet weak
post them up for sheepey</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MRVYBES »</TD></TR><TR><TD CLASS="quote">Brad, what kind of compression are you running on that bad boy?</TD></TR></TABLE>
it was in the 13's somwwhere i dont rember.. That motor was frim like 15 months ago...
It was 8cc piston
.005 to .008 in the hole
.040 gasket
and like a 43.5 chamber
it was in the 13's somewhere ..
Maybe like a 13.5 ...
it was just a test engine
It was 8cc piston
.040 gasket
I have an 85*89 ls/vtec
12.3:1 Wiseco IBSPEC super dupers
Stock GSR Head
Blox IM
70mmTB
Headertech 3" Header
I originally used Rocket Motorsport M24's, but they were too big for the motor. I was only getting about 250psi compression test b/c the huge duration causing overlap. I made 205/150. Switched to JunIII's made 215/155, now i switched to BC4 and they feel even stronger. Hoping for atleast 215/160!
Stock GSR Head
Blox IM
70mmTB
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXEE8 »</TD></TR><TR><TD CLASS="quote">
89x84.5 IB Spec Wiseco 3.6 cc dome ~ 12.3:1
RLZ stage3 head
IB Spec cams
JG Sheetmetal IM
72 mm TB
SMSP B20VTEC header
Brad's heads makes powah
what are the specs to those cams?
RLZ stage3 head
IB Spec cams
JG Sheetmetal IM
72 mm TB
SMSP B20VTEC header
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHEETAH »</TD></TR><TR><TD CLASS="quote">sheepey i should have a customers, will check with him first if he's cool i'll post it up.
greg</TD></TR></TABLE>
That would be cool Greg. i'd like to see more pump gas motors rather than race gas motors.
keep em comin though!
