Mugen Bushing Question
Old Jul 23, 2005 | 12:03 PM
Flux's Avatar
Default Mugen Bushing Question
I jsut received the Mugen rear trailing arm bushings as well as the Front Comliance set. I know that I will need to get a shop to press out the rear trailing arm bushings, but it looks like the front compliance bushings can be uninstalled/installed without the need for a press.
Can anybody with experience with these bushings confirm this? I haven't crawled under the car yet...
thanks.
Old Jul 23, 2005 | 03:58 PM
Pondus's Avatar
Default Re: Mugen Bushing Question (Flux)
Front compliance is a bolt on affair, that's correct. There's a nut on the arm and 3 bolts into the subframe that you need to loosen to get it out.
Old Aug 2, 2005 | 01:34 AM
chulun's Avatar
YES, THAT'S RIGHT.... is easy to install FRONT COMPLIANCE.
Old Aug 2, 2005 | 02:16 PM
Willard's Avatar
Default Re: Mugen Bushing Question (Pondus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pondus &raquo;</TD></TR><TR><TD CLASS="quote">Front compliance is a bolt on affair, that's correct.</TD></TR></TABLE>
Just put the 3 bolts back in the correct locations and load the suspension to normal ride hieght before you tighten the nut.
Old Aug 2, 2005 | 06:51 PM
egtwincam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux &raquo;</TD></TR><TR><TD CLASS="quote">I jsut received the Mugen rear trailing arm bushings as well as the Front Comliance set. I know that I will need to get a shop to press out the rear trailing arm bushings, but it looks like the front compliance bushings can be uninstalled/installed without the need for a press.
thanks.</TD></TR></TABLE>
Make sure the shop presses in the rear trailing arm bushing the proper position! its ssuppoose to be about 10mm to the edge of the trailing arm(side toward the center of the car.)
importboi22
Suspension & Brakes
11
Feb 28, 2005 12:33 AM
93civicsedan
Jun 8, 2004 02:57 PM
jonsteR
May 29, 2003 09:57 AM
