need help...searched
just a little background info. i have an 89 hf crx that i did a b18a swap into. i used the stock crx motor harness, soldered in new clips for the b18 injectors, then i tryed repining the distributor, using the stock crx plug. so here is what i need, i need a picture of the stock wireing of an 89 hf crx distributor.
Thanks in advace J.D.
why will no one help me with this? i've looked for diagrams, forumns, i've looked in honda books, and still am no closer than when i started. i know it's been done, but how?
When I get home tonight I can get a picture of the HF distributor. But I doubt the wire colors will be the same. You'll probably need to trace them back to the ECU and figure out what needs to happen. I.E. (totally making up colors) Red = Crank Angle Sensor on HF, Pink = Crank Angle Sensor on B18. So then you solder red to pink and put it in the correct pin on the b18 ECU (whichever pin the CAS goes in). Know what I mean brosef?
C_REX
Aug 9, 2005 10:26 AM
