Passenger Airbag Tray Question
Does the top part of the SRS airbag that you see on the dash come off by just prying or do you need to take the entire airbag assembly out to remove and replace the tray.
you need to remove the entire airbag assembly... that's what it does... airbag delete! disconnect battery wait about 45 minutes to drain the back up power on the airbags, disconnect the yellow harness below that airbag, remove and put on the JDM tray
homeskillet
Feb 1, 2011 06:26 AM
