Fuel Problems at Half Tank Everytime
Old Jul 23, 2005 | 07:14 AM
Dropped90Integra's Avatar
Default Fuel Problems at Half Tank Everytime
Ok, this is getting annoying, I have a 90 Accord EX with 201K, everytime I hit a half tank, my car stops getting gas, it starts shuttering, not wanted to start when I make turns it cuts off etc etc.... but when I fill it, perfectly fine. What the heck is going on with this damn thing?
Recently, I replaced cap, rotor, plugs, wires, fuel filter, pcv, and cleaned the injectors. I can't think of what could be doing this besides maybe the wrong fuel pump being in the car but I wanna make sure it not something else thats real stupid
Old Jul 23, 2005 | 09:22 AM
Vanilla Sky's Avatar
possibly a fuel tank problem. broken baffles can cause a problem like that.
Old Jul 23, 2005 | 09:53 AM
xbn83's Avatar
Default Re: Fuel Problems at Half Tank Everytime (Dropped90Integra)
Check fuel pump or remove the tank and see.
Old Jul 23, 2005 | 12:53 PM
What are baffles? So ya'll think its gotta be something with my fuel tank/pump... nothing else possible for a problem like this?
Old Jul 24, 2005 | 02:07 PM
lexteckademics's Avatar
I have a 1994 Accord and if i am below a quater tank and take a corner fast mine shuts off to. My fuel rail and filter works fine. Still working on problem.
Old Jul 24, 2005 | 02:08 PM
Old Jul 24, 2005 | 06:30 PM
Yea, its annoying me too, I don't know what it could be... I know its something to do with the gas tank or pump but I wanna see if anyone else had this problem before. I would just drop the tank but I wanna know before I do that... I never have time to fix stuff so when I do its gotta be right the first time basically
Old Jul 25, 2005 | 06:20 AM
exbrick's Avatar
I don't know how these fuel systems or set up, but it could be a weak or dead in-tank pump. Some cars have two fuel pumps: one in the tank to prime the line and then a main pump closer to the engine which actually pressurizes the business-end of the system. In the event of an in-tank pump failure, there is sometimes enough pressure to get fuel up the line when the tank is full. As the fuel level falls, so does the hydrostatic pressure at the pickup and fuel no longer gets to the main pump. I'm new to Accords, but that's where I'd put my money based on the symptoms.
Old Jul 25, 2005 | 08:21 PM
deserthonda's Avatar
Default Re: Fuel Problems at Half Tank Everytime (exbrick)
yo ex on the 2 fuel pumps issue i would not bet too much if i were you ............
yo dropped,,,,, remove fuel pump and chk the sock make sure it is not partially plugged ,,,sometimes when fuel pumps wear down you get metallic particles in the sock and it partially gets plugged ,,,,if there are metallic particles you need fuel pump anyho it is just a matter if time for it to go kaput
Old Jul 26, 2005 | 04:21 AM
Default Re: Fuel Problems at Half Tank Everytime (deserthonda)
Thanks... how hard is a fuel pump on a 90 EX Accord.... tank gotta be dropped don't it?
Old Jul 26, 2005 | 05:09 AM
yep on thismodel there is no axxess hole tank must be dropped
vegava
Oct 6, 2012 12:10 PM
MoneySink
Sep 27, 2011 04:48 AM
sjteg
Oct 27, 2008 10:44 AM
krarthur
Jan 19, 2004 12:40 PM
chiefvtec
Mar 28, 2003 11:40 AM
