LSVTEC, ITR header, and oil pan problem
Old Jul 23, 2005 | 06:48 AM
LSVTEC 91 Civic's Avatar
Banned
Default LSVTEC, ITR header, and oil pan problem
I've been having some problems with my oil pan ever since I put my ITR header on. I have the LS oil pan, and when I went to install my ITR header, the header tube was touching right on the oil pan, so I had to bang it in a little bit so it would fit. Now I'm starting to develop some nasty oil leaks, and I think the pan is warped or something, because I've already replaced 2 oil pan gaskets.
So my question is, is the LS oil pan any different than the B16 oil pan? Would I have clearance issues with the header if I used a B16 oil pan instead?
If I did use a B16 oil pan, will the LS pickup work with the oil pan?
Help!
Old Jul 23, 2005 | 08:23 AM
BigBodySmith's Avatar
Just get in touch with Len and get a type r pan, p/u, and tray. ur problem solved
Old Jul 23, 2005 | 12:10 PM
ohjolt2's Avatar
I have heard of people just letting them touch and having no problems even in the summer.
Old Jul 23, 2005 | 04:55 PM
Banned
Default Re: (BigBodySmith)
So the Type R pan is different from the B16 and LS pan?
Old Jul 24, 2005 | 12:30 AM
redlineintegra's Avatar
Default Re: (LSVTEC 91 Civic)
Yes.
Old Jul 24, 2005 | 07:19 AM
Banned
Default Re: (redlineintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlineintegra &raquo;</TD></TR><TR><TD CLASS="quote">Yes.</TD></TR></TABLE>
Well, now that explains why the ITR header rubs against the oil pan...
Old Jul 25, 2005 | 10:04 AM
Colt Seavers's Avatar
So are going to tell him he needs a 3 main gurdle to or what.
You should just tell him to get a gsr block and call it a day.
Old Jul 25, 2005 | 10:25 AM
Malgerus's Avatar
Default Re: (Colt Seavers)
I'm running an LS/VTEC as well, and I'm using an OEM ITR header... not the nice JDM style one, but the USDM one. I'm also using an LS oil pan. I have no issues with rubbing at all. I can also verify that the B16/LS ones are exactly the same, as I;ve used an LS pan and a B16 pan on my old B16A with no issues.
E.
Feb 27, 2008 06:15 PM
QuickDxEk
20
Dec 3, 2007 07:29 PM
cyrix12
Mar 6, 2006 10:30 PM
crazi92hb
Feb 22, 2006 10:01 PM
trustbuddy
Oct 20, 2004 06:40 PM
