Install oil squirter in LS block...possible?
Old Jul 23, 2005 | 01:13 AM
JUN-DA6's Avatar
Default Install oil squirter in LS block...possible?
Looking for ANY informations about tapping/installing oil squirter in a LS/B18A/B block. Is it possible? I heard it can be done but can't find any info about it.
Can any one post pictures, write up, or links?
thank you for checking.....
Old Jul 23, 2005 | 07:57 AM
PrettyLude's Avatar
im not sure if the ls has the provision to install it, so you might have to drill and tap for it? why are you doing this anyways?
Old Jul 23, 2005 | 08:11 AM
mmuller's Avatar
Mad Scientist
Default Re: (PrettyLude)
you can drill and tap; but for the cost you could just start off with a gsr block if you ''really'' want the squirters
Old Jul 24, 2005 | 12:29 AM
JUN-DA6's Avatar
I have 3 LS blocks that I am going to boost it, but I know LS block does not have oil squirters to cool down the piston's temperture. I have hear some one did on a B20 block and I am wondering if LS block is the same way to drill and tap it, and where to tap. Is the same location as GSR block?
Any one has any info will be great help!
Old Jul 24, 2005 | 08:23 AM
mmuller's Avatar
Mad Scientist
Default Re: (JUN-DA6)
same location as on the c1's
Old Jul 24, 2005 | 11:56 AM
inspyral's Avatar
Are you planning on building the block? If so, oil squirters aren't necessary for forged pistons.
Old Jul 24, 2005 | 01:32 PM
JUN-DA6's Avatar
But it creats a lot of heat if you put on turbo and I want to make sure not to melt the pistons that's why I want put oil squirters on LS block.
Old Jul 24, 2005 | 01:35 PM
JUN-DA6's Avatar
does any one have spec or instruction to drill and tap the oil squirters on LS block? (like how deep needs to drill, and tap size...)
Old Jul 24, 2005 | 06:34 PM
Hapexamendios's Avatar
wouldnt it be cheaper to just put the LS crank into a gsr block... unless your gonna do all the work putting the squirters in there ?
Old Jul 24, 2005 | 11:18 PM
inspyral's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN-DA6 &raquo;</TD></TR><TR><TD CLASS="quote">But it creats a lot of heat if you put on turbo and I want to make sure not to melt the pistons that's why I want put oil squirters on LS block.</TD></TR></TABLE>
The best way to "make sure not to melt the pistons" would be to make sure it's tuned right. The oil squiters are only meant to cool down the OEM cast pistons in VTEC block that rev relatively higher than non-VTEC blocks. Most builders plug up the holes for the oil squiters if they're building a VTEC block with forged pistons, since they aren't needed for forged pistons.
Old Jul 25, 2005 | 08:37 AM
d16dcoe45's Avatar
Default Re: Install oil squirter in LS block...possible? (JUN-DA6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">
The best way to "make sure not to melt the pistons" would be to make sure it's tuned right. The oil squiters are only meant to cool down the OEM cast pistons in VTEC block that rev relatively higher than non-VTEC blocks. Most builders plug up the holes for the oil squiters if they're building a VTEC block with forged pistons, since they aren't needed for forged pistons.</TD></TR></TABLE>
One reason why smart builders plug them up (with forged pistons) is probably to stabilize the oil pressure (more oil where it is needed most--main and rod bearings). Its just like the Toda "Vtec Killers"-- a good reason for getting rid of the small lobe and the whole vtec mechanism is to stabilize the oil pressure--as the vtec rocker shafts have (I think) something like 64 small holes each--they are just controlled leaks.
Old Jul 25, 2005 | 09:54 PM
JUN-DA6's Avatar
Default Re: (Hapexamendios)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hapexamendios &raquo;</TD></TR><TR><TD CLASS="quote">wouldnt it be cheaper to just put the LS crank into a gsr block... unless your gonna do all the work putting the squirters in there ?</TD></TR></TABLE>
Not if you already have 3 LS blocks in your garage. So it is not cheaper if have to buy a GSR block....
Thank you for all the input, but wouldn't be better put in oil squirters if you running turbo with LS or B20 block? since turbo increse intake air temperture!
Old Jul 27, 2005 | 09:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN-DA6 &raquo;</TD></TR><TR><TD CLASS="quote">Not if you already have 3 LS blocks in your garage. So it is not cheaper if have to buy a GSR block....
Thank you for all the input, but wouldn't be better put in oil squirters if you running turbo with LS or B20 block? since turbo increse intake air temperture!</TD></TR></TABLE> fair enough
7rrivera7
Jan 11, 2004 01:16 PM
internet ay
Sep 12, 2003 09:10 PM
ls_vtec_b18a1
Oct 23, 2002 09:22 PM
