Opinions on Crane Stage 2 cams
Old Jul 22, 2005 | 10:45 PM
Louie_EM1
Guest
Posts: n/a
Default Opinions on Crane Stage 2 cams
Specifically how do you guys like em?
Friendly on the tune?
How's the idle?
What's the power like? Numbers?
(Interested for a B18c1)
Old Oct 13, 2005 | 06:58 AM
Pearl Crx's Avatar
Default Re: Opinions on Crane Stage 2 cams (Louie_EM1)
Bump, I would also like to know.
Old Oct 13, 2005 | 12:06 PM
FairlightRacing's Avatar
Default Re: Opinions on Crane Stage 2 cams (Pearl Crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pearl Crx &raquo;</TD></TR><TR><TD CLASS="quote">Bump, I would also like to know.</TD></TR></TABLE>
Any pix of your ride? Looks good in the avatar.
Old Oct 18, 2005 | 08:46 PM
b.d.racing's Avatar
I've got them in my b18c5 and compared to the itr cams I think they're a little better plus they're not too hard on the pockets.
Old Oct 18, 2005 | 11:16 PM
Icey112's Avatar
Default Re: Opinions on Crane Stage 2 cams (b.d.racing)
ive had a few friends with them in there cars and 2 of my friends that had them there intake cam broke with in a year
Old Oct 19, 2005 | 07:53 AM
Used2beAb16's Avatar
Default Re: Opinions on Crane Stage 2 cams (Icey112)
no problems with the breakage here <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Icey112 &raquo;</TD></TR><TR><TD CLASS="quote">ive had a few friends with them in there cars and 2 of my friends that had them there intake cam broke with in a year</TD></TR></TABLE>
and never heard of it previously. Maybe u thinking crowers??? Or maybe your friends dont know how to intall them???? who knows
Either way.. I run these cams. They make decent power, I would personally recommend the stage III's (if u got the displacement and compression)
But the twos are rough to idle, but make good midrange, and topend to around 8,500 or so. I have had no wear problems with cams or rockers. I ran the REV highlift valvetrain with them and has worked great to 9,500 rpms.
Old Nov 10, 2005 | 05:16 AM
slowdaintegra's Avatar
Default Re: Opinions on Crane Stage 2 cams (Used2beAb16)
i know this is an all motor thread but does any onenknow if the crane stage 2 ar good for turbo i already have them and am debating on using them or just my stock gsr cams the reason i have them is because i couldnt pass them up i got type r valvetrain ctr pistons these cams and omni all motor valves for 300 and sold the valves, pistons for way mor than i paid just wondering if i should sell or try to use them thanks ...
Old Nov 10, 2005 | 08:08 AM
Default Re: Opinions on Crane Stage 2 cams (slowdaintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowdaintegra &raquo;</TD></TR><TR><TD CLASS="quote">i know this is an all motor thread but does any onenknow if the crane stage 2 ar good for turbo i already have them and am debating on using them or just my stock gsr cams the reason i have them is because i couldnt pass them up i got type r valvetrain ctr pistons these cams and omni all motor valves for 300 and sold the valves, pistons for way mor than i paid just wondering if i should sell or try to use them thanks ... </TD></TR></TABLE>
Well right off of cranes site and the install instructions it says for use with FI applications you will just need to reduce the overlap via cam gear tuning.
To do this u just advance the exhaust more than the intake.
Old Nov 10, 2005 | 09:06 AM
blundar's Avatar
Tomorrow / saturday I'm tuning a turbo car with the crane stage 2s so I'll let you know how it goes.
Old Nov 10, 2005 | 11:30 AM
Default Re: (blundar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blundar &raquo;</TD></TR><TR><TD CLASS="quote">Tomorrow / saturday I'm tuning a turbo car with the crane stage 2s so I'll let you know how it goes. </TD></TR></TABLE>
Nice!! Have u ever tuned any n/a apps? Im curious where they like the overlap because crane makes it clear that cam gear tuning is necessary. My setup needed cam gear adjustments just to idle.
Old Nov 10, 2005 | 12:17 PM
blundar's Avatar
Not tune Crane St2 on any NA setups - Pro1s, BC4, M22gen1, BloxB/Sk2St2, Peak Pro Series/Toda C, ITR/CTR
Old Nov 10, 2005 | 12:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blundar &raquo;</TD></TR><TR><TD CLASS="quote">Tomorrow / saturday I'm tuning a turbo car with the crane stage 2s so I'll let you know how it goes. </TD></TR></TABLE> thanks alot i have been trying to find someone with so experence with them
Old Nov 10, 2005 | 02:01 PM
zman's Avatar
i am using crane stage 2 cams and valve train in my mildly built b16. 11.3:1 CR fully worked head, AEBS IM, 64mm t/b, 4-2-1 header w/2.5" collector, 2.5" high flow cat and 2.5" exhaust.
With the stock intake manifold and t/b and a crappy dc 4-1 w/stock cat and 2.25" exhaust i made 165whp and 113tq, tuned with an unknown chip and vafc2. It peaked at 7500rpm and plateau'd until 8200rpm's where the power dropped off.
I've since put on the AEBS IM, fakedata IM gasket, 64mm t/b, 4-2-1 header w/2.5" collector a 2.5" high flow cat and 2.5" exhaust. It pulls much harder especially up top and it pulls all the way to 8500rpm now.
I've also noticed a little rough idle. I've spoken with people running other brand stage 2 cams and they said that their idle was fine.
Old Nov 12, 2005 | 07:09 PM
Default Re: (zman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zman &raquo;</TD></TR><TR><TD CLASS="quote">i am using crane stage 2 cams and valve train in my mildly built b16. 11.3:1 CR fully worked head, AEBS IM, 64mm t/b, 4-2-1 header w/2.5" collector, 2.5" high flow cat and 2.5" exhaust.
I've also noticed a little rough idle. I've spoken with people running other brand stage 2 cams and they said that their idle was fine.</TD></TR></TABLE>
Well some stage 2 cams ie skunk 2 blox, etc have similar to stock primaries with bigger vtec lobes and the cranes have bigger both.
b18pwr
10
Sep 23, 2009 05:28 PM
booget
19
Mar 10, 2008 01:16 AM
JDM_FRONTIN
Jan 17, 2008 08:16 PM
beaneg6
Jan 17, 2006 06:59 PM
adddddaaammmm
Feb 26, 2005 09:00 AM
