:(....death to gsr
Old Jul 22, 2005 | 09:41 PM
I got a honda's Avatar
Default :(....death to gsr
so i think she finally gave up tonight....turbo gsr dieing...dead...on the way home from work on the freeway it started to overheat so i sed ok ill jus drive harder and put the heat on (usually works)...welp this time it went past the "H"...and stayed...wen i got off my exit it was sorta smokin white out the back...then she died on the overpass....got it pushed off the side waited for 30 min too kool started her again and wat do u kno?...she went!...drover home smokin for 15 min....now shes here in the front dead...wat can it be?...thers oil spillage from my couplings but i thik its from the turbo kuz the seals are really bad...other then that i still have a little bit of coolant in the resivoir...and she was overheating the whole way...maybe my headgasket?....help...
Old Jul 22, 2005 | 09:49 PM
gsrious's Avatar
Default Re: :(....death to gsr (iluvboost)
you seriously are an integra torturer.
Old Jul 22, 2005 | 09:51 PM
Bay_707's Avatar
warped block blown headgasket done engine.
Old Jul 22, 2005 | 09:56 PM
EMJAY's Avatar
you abuse you lose...part it, gonna cost to much to fix
Old Jul 22, 2005 | 10:02 PM
Default Re: (kb12)
daaamn.....well i guess ill jus get a new motor....thanx guys
Old Jul 22, 2005 | 10:06 PM
hutchenc's Avatar
Brilliant! When you find out your engine is overheating you gun it? That's just the brightest thing I've heard all day. And then you drove it for 15 minutes more while it was bellowing smoke?
If your reaction to this situation is any indicator of how you've treated your motor in the past...maybe that's the reason it's done in? Just maybe though!
If there's coolant in the oil you've at the very least got a blown head gasket. Since you decided to keep driving it I'd say you've got a warped head and/or block. Your motor is hosed. Time to destroy another one!
Old Jul 22, 2005 | 10:08 PM
SidewaysGSR's Avatar
well if u have white smoke out the tail pipe..thas pretty much blown head gasket at the least..prob more...i'd say get new engine..maybe NA..prob not accoding to your sn..well good luck with the new motor!
Old Jul 22, 2005 | 10:14 PM
gsrious's Avatar
oh yeah... i was just thinking of the irony in your avatar
Old Jul 22, 2005 | 10:15 PM
Jeezer's Avatar
when a car overheats you're suppose to let it cool down.. not make it hotter
Old Jul 23, 2005 | 12:22 AM
apok's Avatar
Your engine is toast.
You probably blew the headgasket and fucked it up more by pressing on.
The cheapest way may not be the most convenient way, but you'll look back and thank yourself for stopping when you have several thousand more dollars in your pocket.
Old Jul 23, 2005 | 05:20 AM
Micha's Avatar
FAILWGN
Default Re: :(....death to gsr (apok)
You need a Bicycle or a set of rollerblades. Not another GSr motor to screw up. I want one too someday.(im serious)
Old Jul 23, 2005 | 05:43 AM
elpiar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvboost &raquo;</TD></TR><TR><TD CLASS="quote">so i think she finally gave up tonight....turbo gsr dieing...dead...on the way home from work on the freeway it started to overheat so i sed ok ill jus drive harder and put the heat on (usually works)...welp this time it went past the "H"...and stayed...wen i got off my exit it was sorta smokin white out the back...then she died on the overpass....got it pushed off the side waited for 30 min too kool started her again and wat do u kno?...she went!...drover home smokin for 15 min....now shes here in the front dead...wat can it be?...thers oil spillage from my couplings but i thik its from the turbo kuz the seals are really bad...other then that i still have a little bit of coolant in the resivoir...and she was overheating the whole way...maybe my headgasket?....help...</TD></TR></TABLE>
You don't deserve an integra
Old Jul 23, 2005 | 07:50 AM
Default Re: :(....death to gsr (elpiar)
ok some replys were kool but some just suked....well see the thing is i was going home to my family from work and wen i was on the freeway and it got very hit i had no choice but to keep on driving because i already knew she was toast i just needed to get home...that why i pushed it....i dont deserve tegs?...comon now what would you have done?...i did not want to be stranded on the freeway so i went all the way...plus i didnt wanna pay the tow...so i did wat i had to do in this situation...and its my onlt car so i knew wat was coming i just pushed her as long as i could....also if i get an ls motor do i need an ls wire harness or can i use the gsr?...i kno ill need the ls ecu aswell.....thanks again guys!.............(gsr motor parting out)
Old Jul 23, 2005 | 08:11 AM
Micha's Avatar
FAILWGN
What replies sucked? What do you expect when you come on here and say that you drove your blown up turbo GSR home? What I would have done, is called a tow truck, and had it towed home. That is exactly what you shoulda done. Now you are gonna spend more money in the end cause you wanted to save a few bucks in the beginning by not getting a tow. Umm, lets compare: Tow truck... maybe 200 bucks. New GSR motor... 2500 or more. Now, which one hits the wallet worse? If you cant afford a Tow, how the hell can you afford a turbo teg? This **** pops up, you need backup money for this stuff. why don't you just buy a cheap *** beater car to drive around most of the time? That would probably be better?
Good luck with your car bud, you need it.
BTW... Bicycles start at 100 bucks at walmart.
Old Jul 23, 2005 | 09:14 AM
5 Speed AP2's Avatar
Default Re: :(....death to gsr (Blu99teg)
Time to move on to the next thing.
You could always buy a Jag.
Old Jul 23, 2005 | 10:12 AM
Default Re: :(....death to gsr (5 Speed Dc2)
blue99 ur a ***....first off you really think im gonna buy another gsr motor? and for 2500 bux?...wow werever you buy engines suck....i will never buy another gsr motor for that price...im actually already building an ls/vtec....i was just shareing a story of something i HAD to do..and actually bikes start at 60bux were im from yea 5 speed....i can always jus get a jag huh?....lol...sell me ur car....nah..im fine its all being taken care of...oh wait aparently im gonna need "good luck"........
Old Jul 23, 2005 | 10:29 AM
Bikes are gangsta.
Old Jul 23, 2005 | 11:14 AM
GsrGilbert's Avatar
i dont see why people spend so much money and put so much time into there cars and motors just to play retarded when it comes to taking it easy on their cars. why cant we protect our investments and keep them running. god.
Old Jul 23, 2005 | 11:59 AM
jdmsiR20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blu99teg &raquo;</TD></TR><TR><TD CLASS="quote">What I would have done, is called a tow truck, and had it towed home. That is exactly what you shoulda done. Now you are gonna spend more money in the end cause you wanted to save a few bucks in the beginning by not getting a tow. </TD></TR></TABLE>
yep....
well, if you already knew it was toast dont come here with a sad face... it was your only car too? dang, pull the bitch over... good luck with the new one
Old Jul 23, 2005 | 04:27 PM
Default Re: :(....death to gsr (jdmsiR20)
who sed i came here with a sad face?....i cant simply come here and just add a story dumb or not?...jesus people....so uptight....everyone caaalm down and breeath...everything is oook...all i asked was "what could it be?"...not "am i stoopid?" or "oh man what should i do now?".....ok so i knew it was going out and i HAD to get home the cheapest way...AND?...i also have a 91 si and a 90 crx...and i also didnt spend "alot" of money on my car...
Old Jul 23, 2005 | 05:03 PM
Endless STi's Avatar
better luck on ur next car. "hopefully"
Old Jul 23, 2005 | 05:09 PM
Micha's Avatar
FAILWGN
And your a ******* idiot but I didn't point that one out in the beginning did I? How the hell are you gonna handle a LS/vtec if you cant even handle boost? They kinda go hand in hand with maintenance. I seriously feel sorry for whatever car you drive, I really do.
Plus you made it way clear that you are an idiot... case in point... <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvboost &raquo;</TD></TR><TR><TD CLASS="quote">i also have a 91 si and a 90 crx</TD></TR></TABLE>
When clearly in the beginning you said...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvboost &raquo;</TD></TR><TR><TD CLASS="quote"> had to do in this situation...and its my onlt car so i knew wat was coming i just pushed her as long as i could.... </TD></TR></TABLE>
You sir... are an idiot. Please refer to my signature below, if you don't like it, then leave. Please. Really. Leave. Now.
Old Jul 23, 2005 | 05:16 PM
Micha's Avatar
FAILWGN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvboost &raquo;</TD></TR><TR><TD CLASS="quote">blue99 ur a ***....first off you really think im gonna buy another gsr motor? and for 2500 bux?...wow werever you buy engines suck....i will never buy another gsr motor for that price...im actually already building an ls/vtec....i was just shareing a story of something i HAD to do..and actually bikes start at 60bux were im from yea 5 speed....i can always jus get a jag huh?....lol...sell me ur car....nah..im fine its all being taken care of...oh wait aparently im gonna need "good luck"........</TD></TR></TABLE>
You will need good luck. I really don't care if I am a ***(but my wife won't agree with you). I am pointing out the truth. Oh... Gsr motors are expensive when you are buying them legit(i.e. not stolen). Get it. Thanks. And yoou didn't have to drive your car hard when it was on its last leg. Jeez. Just get something boosted from the factory... i.e. 1988 Turbo sprint 1.0 liter.
Old Jul 23, 2005 | 07:30 PM
elpiar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvboost &raquo;</TD></TR><TR><TD CLASS="quote">who sed i came here with a sad face?....i cant simply come here and just add a story dumb or not?...jesus people....so uptight....everyone caaalm down and breeath...everything is oook...all i asked was "what could it be?"...not "am i stoopid?" or "oh man what should i do now?".....ok so i knew it was going out and i HAD to get home the cheapest way...AND?...i also have a 91 si and a 90 crx...and i also didnt spend "alot" of money on my car...</TD></TR></TABLE>
I just feel sad for your 'teg and had to express it. I feel more sorry for the car than for you...
Please treat it with more respect next time. It's not like you're in a life emergency or sth.
Old Jul 23, 2005 | 08:09 PM
Gant's Avatar
get a new engine, while getting a new engine, (not trying to be a jackass) learn more about engines in general.
what you should of done was just pull over and call a tow truck instead of pushing it hard
good luck
