Converting a from 0bd0 to obd1
Old Jul 22, 2005 | 09:12 PM
teler86's Avatar
Default Converting a from 0bd0 to obd1
i was wondering exactly what parts i need in order to convert my b16 from obd0 to obd1. Also how much does this usually cost. the main reason I am doing this is because i am running super rich and have tried everything else, hopefully this will solve my problem. Any input is apreciated
Old Jul 22, 2005 | 11:08 PM
ICeDoUt's Avatar
Default Re: Converting a from 0bd0 to obd1 (teler86)
well #1 search cause this has been covered 1 million times..... but
u'll need:
conversion harness-about $110
ecu- price ranges depends on ecu
4 wire o2 sensor- $50 bucks used
obd1 dizzy- about $110 area, unless bought new
I don't think i missed anything, but anyone else can chime in
Old Jul 23, 2005 | 02:54 PM
teler86's Avatar
Default Re: Converting a from 0bd0 to obd1 (ICeDoUt)
what kind of ecu should i get
Old Jul 23, 2005 | 03:08 PM
Pee Wee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teler86 &raquo;</TD></TR><TR><TD CLASS="quote">what kind of ecu should i get</TD></TR></TABLE>
a P28 and then chip it to what ever you need
Old Jul 23, 2005 | 03:27 PM
uselesslabel's Avatar
or you could just chip your OBDO ecu
Old Jul 23, 2005 | 03:53 PM
turboZChatch's Avatar
Default Re: (uselesslabel)
Hit up the guys at rywire.com they are super fast, clean and do very quality work they just did my 90 dx to obd1 vtec conversion for me there also honda-tech members NikoZai and droppedcrxsi are there names
Old Jul 26, 2005 | 01:50 PM
teler86's Avatar
Default Re: (turboZChatch)
heres another thing that confuses me, i am going to go from 2 o2 sensors to 1 4wire o2 sensor so will i need a new header?
Old Jul 27, 2005 | 04:53 AM
Pee Wee's Avatar
Default Re: (teler86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teler86 &raquo;</TD></TR><TR><TD CLASS="quote">heres another thing that confuses me, i am going to go from 2 o2 sensors to 1 4wire o2 sensor so will i need a new header?</TD></TR></TABLE>
no just plug the secondary bung
Old Jul 27, 2005 | 05:19 AM
RA122324's Avatar
http://www.rywire.com
http://www.jkobd.com
Old Jul 27, 2005 | 05:45 AM
dr_latino999's Avatar
You can do the wiring yourself if you have the time and patience.
Old Aug 1, 2005 | 08:33 PM
gutted's Avatar
Default Re: Converting a from 0bd0 to obd1 (dr_latino999)
curious to why you need an obd1 distributor, you dont need a obd1 dist when you convert from obd2 to obd1.
Old Aug 1, 2005 | 08:50 PM
Default Re: Converting a from 0bd0 to obd1 (gutted)
Because both the OBD-1 and 2 distributor fire 24 times per revolution while the OBD-0 only fires 16 times.
Old Aug 1, 2005 | 09:01 PM
EFRue57's Avatar
just out of curiosity, why don't you buy an adjustable fuel pressure regulator and just lower your fuel pressure that way?
Old Aug 1, 2005 | 10:16 PM
goforbroke's Avatar
MEAT PATTY
Default Re: Converting a from 0bd0 to obd1 (EFRue57)
I'm in the process of doing the conversion also, but don't you need the plugs from the obd1 harness to pull into the obd1 distrubutor. You have the obd1 distrubutor plugs onto your obd0 harness, right?
Old Aug 9, 2005 | 12:25 AM
gutted's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Because both the OBD-1 and 2 distributor fire 24 times per revolution while the OBD-0 only fires 16 times.</TD></TR></TABLE>
can you explain this more?
Old Aug 9, 2005 | 01:46 PM
teler86's Avatar
is that where the extra power comes from
on a side note my tensioner went on my b16 timing belt and i think that blew my head gasket is that possible?? anyone?
Old Aug 9, 2005 | 06:26 PM
Renegade's Avatar
if your timing belt tensioner is loose and your timing belt is loose that means that you bent your valves.
Old Aug 14, 2005 | 05:51 PM
teler86's Avatar
Default Re: Converting a from 0bd0 to obd1 (Renegade)
i'm getting a new block, i took out my spark plugs and saw that they were flooded with oil , also figured out it was the water pump that took a **** not the tensioner. i get a break from work and school starting friday going to pull the motor.
SickFinga
Feb 25, 2007 10:22 PM
asocallocal
May 30, 2005 10:11 PM
blackcomet
11
Dec 1, 2004 07:33 PM
superls92
Feb 16, 2004 07:38 PM
