searched. Q about dizzy conversion obdII to obdI
Old Jul 22, 2005 | 08:11 PM
knightnam's Avatar
Default searched. Q about dizzy conversion obdII to obdI
I am swapping a 94 obdI B18B into my 97 Integra LS. I have an obdI dizzy to go along with this but am at a loss as to how I should convert the wiring off of my obdII harness for this to work. If anyone has a diagram or schematic of some sort it would be greatly appreciated. Thanks,
Old Jul 23, 2005 | 12:31 AM
apok's Avatar
Default Re: searched. Q about dizzy conversion obdII to obdI (knightnam)
You'll need a different plug since OBD2 has a different wiring scheme than OBD1. Might be better to junkyard an OBD1 harness. There's hundreds of Integras in the junkyard.
Old Jul 23, 2005 | 07:38 AM
knightnam's Avatar
Default Re: searched. Q about dizzy conversion obdII to obdI (apok)
i understand that i need a different plug, i have both obd-1 and 2 dizzys at home. im just wondering how to wire them up. especially having problems with the crank angle sensor.
Old Jul 25, 2005 | 08:06 AM
knightnam's Avatar
bump, does anyone have a color to color diagram or schematic???
Old Jul 25, 2005 | 09:21 AM
HARI.'s Avatar
do you have the obd2 distributor? why don't you just convert the motor to obd2. you'll need the obd2 distributor, ecu, and injectors.
jdmcivic1999
Jun 3, 2009 10:44 AM
Patrickchampagne2006
Mar 21, 2007 02:35 PM
ExplicitSpeed360
May 28, 2006 08:21 AM
ExplicitSpeed360
May 27, 2006 12:31 PM
bruthaboost
Nov 9, 2001 06:34 AM
