how did you improve driving skills ?
Old Jul 22, 2005 | 07:11 PM
project dc2's Avatar
Default how did you improve driving skills ?
well i got a 4 dr integra. i raced last week at the track with 225.50R15 BFG DR's
car makes 300 WHP 250 torque in fstreet form
i lit em up and got a little smoke out of them. preload at 5K and dropped the clutch n smashed the throttle.
no matter what. with drag racing i just suck. road racing im coo i can take turns very well but when it comes to launchign with that much power its pretty difficult.
any of you first started drag racing and noticed you just suck really bad ? lol
im curious as to how you guys improved your times , what methods you tried and what not. tahnks
Old Jul 22, 2005 | 07:24 PM
D-tuned's Avatar
Default Re: how did you improve driving skills ? (project dc2)
Pratice, Pratice, Pratice
Old Jul 22, 2005 | 07:33 PM
SlowReaction's Avatar
Default Re: how did you improve driving skills ? (2000civicsi)
How many psi do you run on the radial? How many psi are you leaving the line at? Dont slam on the throttle once you take off, feather the peddle when you take off.
Old Jul 22, 2005 | 10:47 PM
JL's Avatar
JL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000civicsi &raquo;</TD></TR><TR><TD CLASS="quote">Pratice, Pratice, Pratice</TD></TR></TABLE>
Old Jul 23, 2005 | 05:58 AM
hondaguyef's Avatar
Default Re: how did you improve driving skills ? (JL)
Sounds like you are doing everything right. I would try to play w/ the Tire pressure and tire temp (morre heat) to find the sweet spot. Also look into some limit straps, LSD and a traction bar. You have alot of torque there so, it may tricky but, <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000civicsi &raquo;</TD></TR><TR><TD CLASS="quote">Pratice, Pratice, Pratice</TD></TR></TABLE> and things are sure to come around. Good luck.
Phil
Old Jul 23, 2005 | 09:00 AM
Default Re: how did you improve driving skills ? (SlowReaction)
14 psi tire pressure. small burn out. i have a difficult time getting them to smoke. i dip it in water and burn em. and it usually pulls me right out of my burn out. 5K RPM preload clutch and dump.
with that much torque and my ball bearing turbo it spools super fast so tis difficult to control.
im afraid of modulating the throttle cuz i dont want it to bog and axles to break.
i got traction bar and LSD&gt;
Old Jul 23, 2005 | 10:16 AM
hondaguyef's Avatar
Lower tire pressure for sure and more heat
Old Jul 23, 2005 | 07:52 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000civicsi &raquo;</TD></TR><TR><TD CLASS="quote">Practice, Practice, Practice</TD></TR></TABLE>
Took the words right out of my mouth.
Old Jul 25, 2005 | 01:49 AM
BoOsTiN Dc2's Avatar
ay phil did u use e-brake when u preload? post ur time slips. i just want to compare it to my old setup. Before @ 285hp i did a 13.6 on some bald falken tires (not azenis), doing close to a 2.4 on the 60ft
Old Jul 25, 2005 | 03:49 AM
Retired's Avatar
WEST COAST
Well first you have a street car on dot slicks! This is what i would do. But its going to be alot of load on your engine. Practice your burnout. Burnouts will need to be practiced for good times! Me personally I would pull the ebrake or ( Staging Break ) then put the car in first then put it right into second gear get some nice speed on those tires to heat them up. Rev the car up to about 9k ( a 2 step never hurts) and let it pull its self out of the box. Remeber your not a pro car so going past the tree is not in your picture! Also you have a good 10sec to burnout take your time and practice.
Now for your launch, no matter what you going to have to ride 1st gear. Depending what you rev limiter is. If its was mine 10.2k would be my rev limit your going to spin them mostly out of the hole so your going to have to get that rpm up so you dont have any second gear lag on slicks you would bog down so i would rev it up to 10 so second will catch around 7k still spining but youll see a improvement in your time. After that 3rd 4th etc you got it from thier. Remember your launch and controller of you car is the most important thing. It just takes alot of time and practice. Alot of times before i could even drive i would practice power shifting and pedal and clutch pivots so its not going to come to over night but practice makes perfert
I hope I helped you a little, I know its not the best discreption but its 4:30am right now maybe I right it again when I wake up!
Old Jul 25, 2005 | 08:15 AM
Default Re: how did you improve driving skills ? (tRaCeBuStAbUsTeR)
yea i used Ebrake. this time i honestly just wanted to spin the **** outta the dr's and get home at least. and i even barelyd id so as my clutch crapped out
car 216-
run 1
RT-.552
60"- 2.472
330"- 6.287
1/8-9.221
MPH-85.35
1000"-11.695
1/4-13.783
MPH-108.31
RT-.463
60"-2.474
330"-6.237
1/8-9.105
MPH-86.88
1000"-11.540
1/4-13.56
MPH-110.06
RT-.269
60"-2.776
330"-6.682
1/8-9.707
MPH-83.90
1000"-12.221
1/4-14.339
MPH-108.58
car 216-
run 1
RT-.552
60"- 2.472
330"- 6.287
1/8-9.221
MPH-85.35
1000"-11.695
1/4-13.783
MPH-108.31
RT-.463
60"-2.474
330"-6.237
1/8-9.105
MPH-86.88
1000"-11.540
1/4-13.56
MPH-110.06
RT-.269
60"-2.776
330"-6.682
1/8-9.707
MPH-83.90
1000"-12.221
1/4-14.339
MPH-108.58
Old Jul 25, 2005 | 01:11 PM
damn thats some badass 60ft on dr. i thought i had traction problem with my old setup
r/t .062
60ft 2.384
330ft 6.128
1/8 9.077
mph 82.37
1000 11.578
1/4 13.693
mph 107.68
the other day at the track i hit .001 on the r/t. almost perfect lol
Old Jul 25, 2005 | 02:00 PM
well i just made sure i spun my wheels so i could at least get home. i didnt wanna bog and break an axle or anything.
Old Jul 25, 2005 | 04:52 PM
paulzy's Avatar
the trick is not to have wheelspin
Old Jul 27, 2005 | 05:57 PM
T4eg's Avatar
Default Re: (paul vang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paul vang &raquo;</TD></TR><TR><TD CLASS="quote">the trick is not to have wheelspin </TD></TR></TABLE>
actually maximun acceleration is obtained with a small % of wheel spin...cant remember the exact figure
just felt like being a smart *** in 10pm lol
But back on topic..as posted above just practice, practice, etc. Seat time does wonders
Old Jul 28, 2005 | 12:26 AM
Default Re: (T4eg)
do you guys hit the rev limter in 1st once it spins to get the tire up to speed ?
Old Jul 29, 2005 | 08:23 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
BRo i say practice
but your dumpin the cltuch feather it out and plat the gass and you'll be good....
preload the the ****** adn ease teh clutch out and i promise it will be nicer! good luck
Old Jul 30, 2005 | 09:26 PM
Default Re: how did you improve driving skills ? (Snoflake)
hehe i guess the biggest thing is i don twanna stick too much and break an axle . i guessi just gotta suck it up .
do you guys hold the thortlte at say .. 75% and just let boost ride the RPm's up to redline ?
Old Jul 30, 2005 | 09:35 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">hehe i guess the biggest thing is i don twanna stick too much and break an axle . i guessi just gotta suck it up .
do you guys hold the thortlte at say .. 75% and just let boost ride the RPm's up to redline ? </TD></TR></TABLE>
yea that will work....bro you wont brake your axels that easy.....just keep it up u will find that spot...
im sticking to my stock AXELS...pep boys lifetime warrenty.....
Old Jul 30, 2005 | 09:48 PM
heheh i broke my 96 ITR LSD on azenis on the street. straight snapped off the launch.
Old Jul 30, 2005 | 09:49 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">heheh i broke my 96 ITR LSD on azenis on the street. straight snapped off the launch. </TD></TR></TABLE>
must be a beast with your left foot then.........
what mount u have?
Old Jul 31, 2005 | 12:38 AM
traction issuez's Avatar
that's some nasty 60' foot timers, usually aim for 2.0 -
what is your rear spring rate? you said u road race? the springs in a
road race is way opposite than drag springs. you have traction bars? etc?
Old Jul 31, 2005 | 08:00 AM
Default Re: how did you improve driving skills ? (boostedrotary)
traction bars
jim fab lower and rear mounts .
i could've done better with my 60's but everyone kept on tellin me make sure it spins make sure it spins so i did. next time out imma slip the clutch and hopefully land a much better 60"
Old Aug 3, 2005 | 11:00 PM
went back
did a 2nd gear burnout helped a TON !
2.1 60" 12.9@112
2.34 60" 13.1@ 114 shifting into 3rd it slipped a bit did 2nd gear burn but tires didnt smoke
